Nortant Posted July 16, 2007 Share Posted July 16, 2007 My atari lynx is continually scrolling up ie on the Ishado program the squares of one row will highlight very quickly from bottom to top of screen and continually scroll round. I thought a button had stuck on. butt all buttons appear to be working ok. the Lynx works perfectly with the back off and circuit board laying down. I was thinking maybe a flat cable is shorted but cant see where. if I put tape over the wires for insulation the fault still comes back when the case is screwed shut. Anyone have an experience of this type and a fix? Quote Link to comment Share on other sites More sharing options...
per Posted July 16, 2007 Share Posted July 16, 2007 not really, but if the problem is somethere else than on the plastic/white foil, you could try to resolder a cable. Quote Link to comment Share on other sites More sharing options...
Nortant Posted July 21, 2007 Author Share Posted July 21, 2007 not really, but if the problem is somethere else than on the plastic/white foil, you could try to resolder a cable. I will open it up again and try to isulate the foilwire at each point it crosses a screw or sharp edge tyhat hopefully will solve the problem. thankyou Quote Link to comment Share on other sites More sharing options...
