per Posted July 19, 2007 Share Posted July 19, 2007 (edited) On this site, http://austevoll.sekkelsten.net/spill/java2/, I have tried to recreate Tile-Game as much as possible in DHTML. The story behind Tile-Game is that I tried to port Chips Challenge to the TI-83/TI-83/84 plus. I used this very speed limited version of BASIC who was included on the calculator, so I couldn't add too many of the tiles. When the project was over, Tile-Game had a total of 40 tiles and an editor, and with an speed of about 2 moves in one seckond. The original Tile-Game is avalible here: http://www.ticalc.org/archives/files/fileinfo/395/39588.html You problably know what Chps Challenge is if you have an atari Lynx or if you like tile based puzzels, but for those who don't know, Chips Challenge is a game for the Atari Lynx, made in 1989 (programmed by Chuck Sommerville at Epyx, you can read his comments about the original Chips Challenge here: http://www.geocities.com/kathyl.geo/chips_chuck_page.html). The game is one of the most adictive puzzle games ever created, and it works like this: You are walking around in a level and you are trying to reach an exit. In orther to do this, you have to avoid different kind of traps, push blocks, press buttons, work fast and use keys and tools in a logical way. The original game has 145 normal levels including 4 hidden ones + an fractal plotter (Chuck allways added some kind of easter egg in his Atari Lynx games). But anyway, What do you think? *Edit* If the window looses enough focus when you are playing the game, all the image resources will be removed form your computer's buffer memory and the game will run into some problems by refreshing the images. I am currently working on fixing this issue. Edited July 19, 2007 by per Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted July 19, 2007 Share Posted July 19, 2007 Does it require a certain browser? I use Firefox. After I allow JavaScript, a menu comes up, but I can't do anything. Quote Link to comment Share on other sites More sharing options...
per Posted July 19, 2007 Author Share Posted July 19, 2007 (edited) Does it require a certain browser? I use Firefox. After I allow JavaScript, a menu comes up, but I can't do anything. Try to press the up or down arrow keys, and the arrow should move. *Edit* Then press enter when the arrow is pointing on the option you want. Edited July 19, 2007 by per Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted July 19, 2007 Share Posted July 19, 2007 Does it require a certain browser? I use Firefox. After I allow JavaScript, a menu comes up, but I can't do anything. Try to press the up or down arrow keys, and the arrow should move. *Edit* Then press enter when the arrow is pointing on the option you want. That worked. Thanks. Quote Link to comment Share on other sites More sharing options...
per Posted July 20, 2007 Author Share Posted July 20, 2007 Everybody who wants to can share the codes for their own levels in this thread too, your levels will problably appear in the buildt-in levelset in the future if you do so, unless you tell that you don't want it there. Quote Link to comment Share on other sites More sharing options...
per Posted July 30, 2007 Author Share Posted July 30, 2007 If the window looses enough focus when you are playing the game, all the image resources will be removed form your computer's buffer memory and the game will run into some problems by refreshing the images. I am currently working on fixing this issue. Issue fixed. I also added some sound effects. Quote Link to comment Share on other sites More sharing options...
