meshounah Posted August 2, 2007 Share Posted August 2, 2007 hello i am producing a paintball game and i have my playfield designed with little hay-bales but i would like to make it that those hay-bales restrict movement and block missiles. how would i do this? playfield: ................................ .....X..................X....... .............X..............X... .....X.......................... .........X............X......... ....X.........X.............X... ................................ ..............X................. ...X...................X........ .....X..........X............... ..........................X..... ................................ end player0: 011100 011000 011000 100000 %01011010 %01111100 100100 010000 011000 111100 011000 end x=50 y=50 main COLUP0=28 COLUPF=90 COLUBK=160 player0x=x player0y=y drawscreen if joy0right then x=x+1 if joy0left then x=x-1 if joy0up then y=y-1 if joy0down then y=y+1 goto main Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 2, 2007 Share Posted August 2, 2007 (edited) i would like to make it that those hay-bales restrict movement and block missiles. how would i do this? There are a few ways you can better optimize your current code, and then you will also need to add some things to accomplish what you want to do. First, the optimizations... (You should get in the habit of learning and then using different ways to optimize your code while your program is still small, since it's more of a chore to modify larger programs than smaller programs.) Original code: x=50 y=50 player0x=x player0y=y if joy0right then x=x+1 if joy0left then x=x-1 if joy0up then y=y-1 if joy0down then y=y+1 In your current code, you're using x and y as temporary values to hold player0's x and y coordinates, and increasing or decreasing x and y depending on the joystick input. This is actually a waste of two bB user variables (x and y), because it's redundant (player0x and player0y are bB "system variables," or two bytes of RAM that bB uses for a predetermined purpose). Instead, you can simply set and then modify the player0x and player0y variables directly, as follows: player0x=50 player0y=50 if joy0right then player0x=player0x+1 if joy0left then player0x=player0x-1 if joy0up then player0y=player0y-1 if joy0down then player0y=player0y+1 This has two benefits-- (1) it leaves the two user variables x and y free for something else, and (2) it lets you omit the unnecessary steps of setting player0x to x, and setting player0y to y (which saves a few bytes of ROM). Furthermore, you can save another few bytes of ROM by putting the following statements on the same line of code (separated by a colon), because bB will recognize that both variables are being set to the same value, and it will compile them in a manner that's more compact: player0x=50:player0y=50 Another optimization can be achieved by rearranging the following lines of code: main COLUP0=28 COLUPF=90 COLUBK=160 The statements to set the playfield color and background color don't need to be inside the loop, since those colors will keep their values once you set them. However, you *do* need to set the player0 color inside the loop, since bB overwrites the player0 and player1 colors when it displays the score at the bottom of the screen using the scorecolor (because the score is drawn using player0 and player1, so bB will change the player0 and player1 colors to the scorecolor just before it displays the score, and it will *not* set them back to their original colors afterward). The new order of the statements would be as follows: COLUPF=90 COLUBK=160 main COLUP0=28 This might not seem like much of a change, but it will save some precious machine cycles in the loop, since you don't need to waste machine cycles reperforming any statements that can be performed just once. Right now your loop has plenty of machine cycles to spare, but as your code starts to grow, you might run out of machine cycles, and then you would need to find ways to eliminate any unnecessary steps so you can reclaim machine cycles for doing other things. It's better to keep things tight from the beginning, to get a head start on freeing up as many machine cycles as possible. Thus, the newly optimized version of your code would be as follows: playfield: ................................ .....X..................X....... .............X..............X... .....X.......................... .........X............X......... ....X.........X.............X... ................................ ..............X................. ...X...................X........ .....X..........X............... ..........................X..... ................................ end player0: 011100 011000 011000 100000 %01011010 %01111100 100100 010000 011000 111100 011000 end player0x=50:player0y=50 COLUPF=90 COLUBK=160 main COLUP0=28 drawscreen if joy0right then player0x=player0x+1 if joy0left then player0x=player0x-1 if joy0up then player0y=player0y-1 if joy0down then player0y=player0y+1 goto main Now, on to answering your question... To make the playfield blocks act as objects that get in the way of the sprites' movements-- as opposed to simply being blobs of color on the screen that the sprites can pass through-- you need to check for collisions, and then take appropriate action whenever specific types of collisions are detected. To stop a player when it hits a bale of hay (or playfield pixel), the easiest approach is to save the player's previous x and y coordinates, and then if the player collides with a playfield pixel, set the player's x and y coordinates back to what they were before you moved the player. And the simplest way to do that is to use two user variables to hold the direction that the player is moving in-- one user variable for the change in the x direction, and another user variable for the change in the y direction. You will need to start by setting them both to 0, and then set them to either 1 for an increase, or 255 (which is equivalent to -1 in one-byte numbers) for a decrease, as follows: x=0:y=0 if joy0right then x=1 if joy0left then x=255 if joy0up then y=255 if joy0down then y=1 You'll need to do this *before* you draw the screen, update player0x and player0y by adding these x and y "direction values" to them, and *then* draw the screen, as follows: x=0:y=0 if joy0right then x=1 if joy0left then x=255 if joy0up then y=255 if joy0down then y=1 player0x=player0x+x player0y=player0y+y drawscreen This way, if the joystick isn't being pushed in any direction, then x and y will be 0, and player0x and player0y will stay the same. Otherwise, x and y will be set depending on which way the joystick is being pushed, and player0x and player0y will be updated accordingly, then the screen will be drawn using the new player0x and player0y values. Next, you'll need to check for a collision between player0 and the playfield. This needs to be done *after* drawing the screen with the new player0x and player0y vcalues, because in order to detect a collision, you must first allow the collision to occur (makes sense, right?), and collisions occur when two things overlap each other as the screen is being drawn. Furthermore, when a collision *does* occur between player0 and the playfield, you'll need to reset player0x and player0y to their previous values, by "undoing" the addition of the x and y direction changes (i.e., subtracting the changes to reverse the effects of having added them). You'll need to do this right away, *before* looping back to where x and y get set to new values based on the joystick: drawscreen if collision(player0,playfield) then player0x=player0x-x:player0y=player0y-y goto main So the updated program will look like this: playfield: ................................ .....X..................X....... .............X..............X... .....X.......................... .........X............X......... ....X.........X.............X... ................................ ..............X................. ...X...................X........ .....X..........X............... ..........................X..... ................................ end player0: 011100 011000 011000 100000 %01011010 %01111100 100100 010000 011000 111100 011000 end player0x=50:player0y=50 COLUPF=90 COLUBK=160 main COLUP0=28 x=0:y=0 if joy0right then x=1 if joy0left then x=255 if joy0up then y=255 if joy0down then y=1 player0x=player0x+x player0y=player0y+y drawscreen if collision(player0,playfield) then player0x=player0x-x:player0y=player0y-y goto main There are other changes you'll probably want to make, such as preventing player0 from moving too far left, right, up, or down, but I won't get into that yet, since I don't know how far you want to let player0 move in those directions. You can also set player0 to a reflected image if it's moving left; but again, I won't get into that just yet. Michael Edited August 2, 2007 by SeaGtGruff Quote Link to comment Share on other sites More sharing options...
meshounah Posted August 2, 2007 Author Share Posted August 2, 2007 ok thank you that helps a bunch Quote Link to comment Share on other sites More sharing options...
