BSA Starfire Posted August 2, 2007 Share Posted August 2, 2007 The title says it all really, just want to avoid buying games that won't work. I'm sure I have read somewhere that Demon Attack won't work on the XE but can't remember where, is this true? Also any others that won't play. Thanks all! Chris Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 2, 2007 Share Posted August 2, 2007 It's the same deal as for XL software. But there are very few carts that aren't compatible - I think there's a list somewhere. Of those, probably all would be available as executable files anyway, so you could run them from disk. For disk based stuff, it's not so much a problem since fixes have been made for just about everything that wasn't XL/XE compatible. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 2, 2007 Share Posted August 2, 2007 It's the same deal as for XL software. But there are very few carts that aren't compatible - I think there's a list somewhere. Of those, probably all would be available as executable files anyway, so you could run them from disk. For disk based stuff, it's not so much a problem since fixes have been made for just about everything that wasn't XL/XE compatible. I love to see a NTSC/PAL fix, without having to mod the hardware. Quote Link to comment Share on other sites More sharing options...
mimo Posted August 2, 2007 Share Posted August 2, 2007 k-star Patrol shame 'cus it is a good game Quote Link to comment Share on other sites More sharing options...
mimo Posted August 2, 2007 Share Posted August 2, 2007 ripped from the 8 bit faq Subject: 8.4) What programs run only on the 400 and 800 models, and why? The following are reported as incompatible with models other than the original Atari 400/800. Most probably do work on XL/XE's if you use a translator to run the original 400/800 OS on your XL/XE. Apple Panic Broderbund Aquatron Sierra On-Line Astro Chase (by First Star Software) Parker Bros. Atari Word Processor Atari (this is not the same as AtariWriter!) Atlantis (some versions!) Imagic Attack at EP-CYG-4 (by Bram) Romox Bacterion! Kyle Peacock/Tom Hudson/ANALOG#20 ( [url="http://www.cyberroach.com/analog/an20/bacterion.htm"]http://www.cyberroach.com/analog/an20/bacterion.htm[/url] patch for XL/XE available: [url="http://www.cyberroach.com/analog/an20/bacterion_patch.htm"]http://www.cyberroach.com/analog/an20/bacterion_patch.htm[/url] ) Bandits Sirius Software BearJam Chalkboard Boulders And Bombs CBS Chicken Synapse Dancing Feats (by Softsync) Romox Demon Attack Imagic Dreadnaught Factor, The Activision Drelbs Synapse File Manager 800+ Synapse Forbidden Forest Cosmi (later versions by different companies work ok on XL/XE!) Fort Apocalypse Synapse (cart version is 400/800 only! tape+disk versions work ok on XL/XE!) Galahad And The Holy Grail APX (Downloadable: [url="http://www.atariarchives.org/APX/showinfo.php?cat=20132"]http://www.atariarchives.org/APX/showinfo.php?cat=20132[/url]) Go Hayden Gorf Roklan Jawbreaker II Sierra On-Line Jet Boot Jack English Software (can be found on various tapes/disks; at least the re-release version by Byte Back works alright on XL/XE computers!) Juggler IDSI K-Razy Antiks K-Byte K-razy Kritters CBS K-razy Kritters K-Byte Kangaroo Atari prototype KoalaPainter Koala Leo's 'Lectric Paintbrush Chalkboard Leo's Links Chalkboard Letter Perfect (before v6) LJK LogicMaster Chalkboard Mac/65 [ver. 1.00, orange] OSS Mario Bros. ('83) Atari Maze Epyx Micro Illustrator Chalkboard MicroMaestro Chalkboard Monkey Wrench Eastern House Monster Maze Epyx Ms. Pac-Man Atari (has problems with newer XE/XEGS computers!) M.U.L.E.(early release only) Electronic Arts Nautilus Synapse Pac-Man Jr. Atari prototype Picnic Paranoia Synapse Pool 1.5 IDSI Pool 400 IDSI Protector II Synapse QS Forth James Abanese / [QS] Quality Software Rack 'Em Up Rocklan Shamus Synapse Slime Synapse Snapper Silicon Valley Systems Space Dungeon Atari Squish 'Em Sirius Super Pac-Man Atari prototype Synassembler Synapse Text Wizard Datasoft Zaxxon (early release only!) Datasoft Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted August 2, 2007 Share Posted August 2, 2007 Rampage will only work with the XEGS keyboard plugged in. Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 1, 2007 Share Posted September 1, 2007 Needed to resurrect this to ask a question. Can anyone confirm if Demon Attack will or will not work on either an 800XL or an XEGS? Thanks! Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted September 1, 2007 Share Posted September 1, 2007 Can anyone confirm if Demon Attack will or will not work on either an 800XL or an XEGS? The Demon Attack cart is OS-B only, ie it will only work on the 400/800. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted September 2, 2007 Share Posted September 2, 2007 For an all systems patched ROM: http://www.atariage.com/forums/index.php?showtopic=88155 Not sure how practical burning a new prom for an original cart is though, e.g. can the case be opened, one or two chips, soldering etc? Certainly the Synapse titles have been patched but IIRC, the Gorf cart uses an area of memory in the XL - one byte of which the OS checks regularly and if changed it locks the machine, and unfortunately there is no other RAM available to remap this too in order to fix it (I suppose this area could be relocated to RAM above 16K but then the game would run on a 800XL/65XE etc but not a 600XL) Plus there exists a file version that can run under an XL translator. Regards, Mark Quote Link to comment Share on other sites More sharing options...
frogstar_robot Posted September 2, 2007 Share Posted September 2, 2007 I love to see a NTSC/PAL fix, without having to mod the hardware. This is too deeply fundamental to be patched in software such that all titles work across the board. PAL has more scanlines and a lower refresh rate than NTSC. Since the most interesting tricks the A8 can do involve interrupts synced to the video this means the actual programming for the two standards varies significantly. Perhaps in time we will see the A8 implemented as an FPGA. Such an implementation could support both PAL and Antic and likely the 5200 as well. Even then, you'd need a monitor capable of both PAL and NTSC video timing. Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 3, 2007 Share Posted September 3, 2007 Can anyone confirm if Demon Attack will or will not work on either an 800XL or an XEGS? The Demon Attack cart is OS-B only, ie it will only work on the 400/800. Thanks for the info. Didn't want to waste money. Good thing that I can just play Demon Attack on the 2600. Quote Link to comment Share on other sites More sharing options...
bones Posted September 7, 2007 Share Posted September 7, 2007 Is there a way to mod the XEGS hardware so that it will play these games as well? Any recommendations on who could do this? Just need NTSC, nothing PAL. Call me crazy, but the XEGS is my primary A8 system...love the detachable keyboard, and mainly just use it for cartridge based gaming. That and it's a heck of a lot easier than messing with a 5200. Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 7, 2007 Share Posted September 7, 2007 (edited) Is there a way to mod the XEGS hardware so that it will play these games as well? Any recommendations on who could do this? Just need NTSC, nothing PAL. Call me crazy, but the XEGS is my primary A8 system...love the detachable keyboard, and mainly just use it for cartridge based gaming. That and it's a heck of a lot easier than messing with a 5200. I have an 800XL and an XEGS. The XE is out right now. I'd prefer to use the XL, because I like its looks more, but... one of my fav games to play is Lode Runner, and it doesn't look right on the XL. It's all red. And of course with the XE you get built-in Missile Command. But then... I usually don't have the XE keyboard out because I usually don't need it. Then I went and got Jumpman Jr. And for that you need the keyboard to start the game - you have to use the number keys to pick the player speed. So, that would work better with the XL. But then Lode Runner works better with the XE. So, my choice was to keep the XE out with its keyboard. Edited September 7, 2007 by Brian R. Quote Link to comment Share on other sites More sharing options...
