walter_J64bit Posted August 12, 2007 Share Posted August 12, 2007 OK, I know how to make a Directory how do you copy files in to that Directory? Quote Link to comment Share on other sites More sharing options...
Mathy Posted August 13, 2007 Share Posted August 13, 2007 Hello Walter C **,SUBDIRN.AME: You can ofcourse copy from anywhere to everywhere. SUBDIRN.AME is just a name I made up. It too can be anything. Just make sure it ends with a colon (that's a : for those reading this and thinking "what's a colon?"). You also have to make sure there's no number on position 1. For instance 1FILE.TXT doesn't mean "do something with the file called 1FILE.TXT", but "do something with FILE.TXT on D1:" BTW as you might have notice, I didn't use a period between both asterixes (that's these **). After a * or if the filename is 8 characters long, you don't need a period. Greetings Mathy Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 13, 2007 Author Share Posted August 13, 2007 (edited) OK, let say files are on D2: is this what I need to type in and the Dir is on D1: C the computer ask File source,destination? Than I put in D2:ga**,D1:new is that right? Edited August 13, 2007 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 13, 2007 Author Share Posted August 13, 2007 (edited) OK, I got it. I think. Thanks! Edited August 13, 2007 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
Beetle Posted August 13, 2007 Share Posted August 13, 2007 You can use Toms Navigator as a Mydos DUP.SYS replacement, too. Makes working with subdirectories fun. Download it here. Quote Link to comment Share on other sites More sharing options...
a8maestro Posted August 28, 2007 Share Posted August 28, 2007 OK, let say files are on D2: is this what I need to type in and the Dir is on D1: C the computer ask File source,destination? Than I put in D2:ga**,D1:new is that right? No. What that will do is copy all of the files that matches D2:ga** to D1:new. You'll end up with 1 file or possibly get an error if the name is used by a directory. Should be D2:ga**, D1:new: Don't forget the trailing colon. And the NEW directory has to already be created. Rick D. Quote Link to comment Share on other sites More sharing options...
atarixle Posted August 28, 2007 Share Posted August 28, 2007 I work with Turbo-BASIC and use "CopyFNF" for doing that: http://andymanone.dyndns.org/atarixle/boss/copyfnf.htm Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 29, 2007 Share Posted August 29, 2007 I work with Turbo-BASIC and use "CopyFNF" for doing that: http://andymanone.dyndns.org/atarixle/boss/copyfnf.htm Looks very useful. Which download should one select for English to get the "FNF?" Thanks, Larry Quote Link to comment Share on other sites More sharing options...
atarixle Posted August 30, 2007 Share Posted August 30, 2007 get this download ... on disk "bossx3d.atr" is the file "COPYFNF.TUR" ... but it is a beta (the program works well, but there are no error traps, and the program doesn't ask if it wants to overwrite a file). You can create folders and copy whole folders with any subfolders ... . http://andymanone.dyndns.org/atarixle/down...ossx/bossx3.zip Quote Link to comment Share on other sites More sharing options...
