autumn_drag0n Posted August 14, 2007 Share Posted August 14, 2007 (edited) I am not sure what is going on but I am sure someone here can help. Here is my problem - I have two Wii Remotes, the first one is detected, no problem. I am have performed a synch between the 2nd Wii Remote and the Wii, that works. Here is the problem when I go to play "WarioWare Smooth Moves", "Rampage World Tour" (basically any 2 player game other than Wii Sports, that works) the light on the bottom of my 2nd Wii Remote is no longer lit and I have no option to play 2 players. I have replaced the batteries in the 2nd Wii Remote also but still no luck Any help with this is very appreciated. autumn_drag0n Edited August 14, 2007 by autumn_drag0n Quote Link to comment Share on other sites More sharing options...
KrazyKaiju Posted August 14, 2007 Share Posted August 14, 2007 Something like this happened to me once but it corrected itself. Wiimote 2 and 3 would disappear when Mario Party started. I'm still not sure what was going on, but it fixed itself when I used my 2nd remote to start the Wii. After I got to the channels menu I tapped the A button on my 1st remote to bring up the cursor. Everything was fine after that. Failing that, maybe you should re-synch both remotes instead of just the one. I don't know much about the bluetooth spec, but possibly they're interfering with each other. Quote Link to comment Share on other sites More sharing options...
rockman_x_2002 Posted August 14, 2007 Share Posted August 14, 2007 My suggestion would be to try to resync all of the remotes you intend on using, in the player order you want. That should take care of the problem. Barring that, you might want to fully power cycle your Wii by unplugging it, waiting a moment, and plugging it up again, then resyncing. Quote Link to comment Share on other sites More sharing options...
