Marius Posted August 14, 2007 Share Posted August 14, 2007 (edited) Hi Folks, A few weeks ago I release my last version of MyFormat. This tool is able to format a 16MB MyIDE Partition into the SpartaDOS file format. This ATR comes with full documentation. The ATR includes: MyFORMAT 2.0 SpartaDOS 3.3a BeWeDOS 1.30 (for use with MyIDE versions without MyIDE OS ROM installed) MySwap 2.0 (tool to swap IDE partitions) MSDOS.COM (great Game/Demo loader for spartaDOS format partitions, made by BEWESOFT) Documentation Please leave any feedback here. Thanks Marius There is an UPDATE of this Software! Scroll down to find it! ( I leave version 2.0 here for people who want to use 2.0 ) Edited August 27, 2007 by Marius1976 Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 16, 2007 Share Posted August 16, 2007 Hi Folks,A few weeks ago I release my last version of MyFormat. This tool is able to format a 16MB MyIDE Partition into the SpartaDOS file format. (snip...) Marius Does Sparta require the Internal or External Rom (or just any MyIDE ROM as opposed to the RAM OS)? -Larry Quote Link to comment Share on other sites More sharing options...
Marius Posted August 16, 2007 Author Share Posted August 16, 2007 Does Sparta require the Internal or External Rom (or just any MyIDE ROM as opposed to the RAM OS)?-Larry Hi Larry, SpartaDOS needs the MyIDE OS eprom inside your Atari 8bit computer. It does not matter what kinds of MyIDE interface card you're using as long you did replace your Atari OS rom with some kind of MyIDE Eprom. If you don't have a MyIDE Eprom inside your atari: BeWe DOS is still a great choice, because it is Sparta Compatible. Good luck! Marius Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 16, 2007 Share Posted August 16, 2007 Does Sparta require the Internal or External Rom (or just any MyIDE ROM as opposed to the RAM OS)?-Larry Hi Larry, SpartaDOS needs the MyIDE OS eprom inside your Atari 8bit computer. It does not matter what kinds of MyIDE interface card you're using as long you did replace your Atari OS rom with some kind of MyIDE Eprom. If you don't have a MyIDE Eprom inside your atari: BeWe DOS is still a great choice, because it is Sparta Compatible. Good luck! Marius Hi Marius- Thanks for the info -- I'll give it a try. My XE MyIDE internal interface uses 4.3I. -Larry Quote Link to comment Share on other sites More sharing options...
Marius Posted August 16, 2007 Author Share Posted August 16, 2007 Hi Marius-Thanks for the info -- I'll give it a try. My XE MyIDE internal interface uses 4.3I. -Larry Oh that's cool! Now you are able to run 3.3a. Make sure you only use the format tool on 65535 sector sized (double density) partitions. It is a non-intelligent routine, so it does not check your sector/density settings. Marius Quote Link to comment Share on other sites More sharing options...
Marius Posted August 26, 2007 Author Share Posted August 26, 2007 (edited) UPDATE!! MyFormat 2.1 Bug Fix: The bootsectors written by my previous released version (2.0) were not 100% compatible with the spartaDOS file format! When you did format your partition with version 2.0, and you are booting SpartaDOS 3.3a, or BeWeDOS 1.30... there is no problem. But: when you want to install another system-file to boot (like a bootmanager) in stead of the .DOS file of your choice, you may have had some troubles (like a non-booting partition) In this new version.... (2.1) this problem is fixed (I hope) Tested with: bootmanager written by Atreju. Sorry for any inconvenience. Please leave any feedback or questions here. Marius Edited August 26, 2007 by Marius1976 Quote Link to comment Share on other sites More sharing options...
