Background kernel option
lord_mike
I'm trying to figure out how to use the background kernel option... supposedly, this option works like pfcolors, only it changes the background color for each playfield line... the problem is, this kernel option is mentioned in the manual, but it completely undocumented... There is some reference to backgroundchange in the source code, but that is all I can figure out this late at night...
I'm trying to bypass the pfheights with pfcolors "one time only" define restriction by using this kernel option instead to create a dynamic multicolored background... I tried the following with no success:
 set kernel_options player1colors pfheights background
 pfheights:
 10
 13
 15
end
 playfield:
 ............X..X................
 ...........X....X...............
 ..........X......X..............
 .........X........X.............
 ........X..........X............
 .......X............X...........
 ......X..............X..........
 .....X................X.........
 ....X..................X........
 ...X....................X.......
end
 COLUPF=203
 background:
 144
 146
 148
 152
 154
 156
 158
 160
 162
 164
 166
end
gameloop
 drawscreen
 goto gameloop
end
It says that the background keyword does not exist.... I haven't seen this issue brought up before, so I don't know where to turn for answers...
Any help would be greatly appreciated!
Thanks,
Mike
Edited by lord_mike
The compiler should not allow that combination of kernel options:
But obviously it is, so you've found a bug. I'm hoping the command reference doesn't claim this is valid as well :)
The issue is that the background option simply takes the pfcolor table and writes to the background instead of the playfield color register. Therefore, the background kernel option must include pfcolors.
IIRC, the timing for the background color write is a little off. That was the reason why I didn't document it very well (aside from laziness.)
Thank you for replying, Batari!
I actually got that combo straight from the manual:
Acceptable combinations:
pfcolors pfheights
pfcolors pfheights background
pfcolors no_blank_lines
pfcolors no_blank_lines background
player1colors no_blank_lines
player1colors pfcolors
player1colors pfcolors pfheights
player1colors pfcolors background
player1colors pfcolors pfheights background
player1colors no_blank_lines readpaddle
player1colors no_blank_lines pfcolors
player1colors no_blank_lines pfcolors background
playercolors player1colors pfcolors
playercolors player1colors pfheights
playercolors player1colors pfcolors pfheights
playercolors player1colors pfcolors background
playercolors player1colors pfheights background
playercolors player1colors pfcolors pfheights background
Ah, yes.. now it works with the pfcolors keyword!
I see... it doesn't look too bad in Stella, though.. the effect is pretty stunning, actually.... now, I have to figure out a hack to make it change colors dynamically... Curtis addressed something similar in another thread... we'll see if it's doable!
Thanks, Batari for such a great product! I've noticed that you haven't updated your blog recently. Have you stopped working on BBasic? :?
Thanks,
Mike
Edited by lord_mike
