theking21083 Posted September 2, 2007 Share Posted September 2, 2007 I just got a Colecovision a week ago and I was trying to open it so that I could mess around inside of it. I took out the 8 screws on the bottom but it seems to be attached at the front. Is their anything else that I need to do to open it up. I didn't want to just yank the cover off and break something. I would appriciate any help. Quote Link to comment Share on other sites More sharing options...
+Psionic Posted September 2, 2007 Share Posted September 2, 2007 It is very hard the first time and I don't know how exactly to explain it...you just have to wiggle it around and get it just right. You have to pull toward you on the front of the casing a bit as you pull up in order to get the front of the top casing dislodged from the bottom piece. It's tricky, but with some patience you'll get it. Hope that helps. Quote Link to comment Share on other sites More sharing options...
EmOneGarand Posted September 3, 2007 Share Posted September 3, 2007 Once you get the Expansion Bay area of the case apart it's smooooth sailing from there.. word to the wise though.. don't touch the controller ports unless your sure you've discharged any static electricity.. from what I hear static destroys the chips. Quote Link to comment Share on other sites More sharing options...
SRGilbert Posted September 3, 2007 Share Posted September 3, 2007 This should help LINK TO PDF Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted September 6, 2007 Share Posted September 6, 2007 There are three screws under the front label. You can either peel the label off very carefully, or you can try to wiggle it apart. Quote Link to comment Share on other sites More sharing options...
theking21083 Posted September 6, 2007 Author Share Posted September 6, 2007 I finally got it. It took some tugging and then when I almost gave up it just kinda fell apart in my hands. Thanks everyone for all your help. I thought I was gonna break it for sure. Quote Link to comment Share on other sites More sharing options...
Artlover Posted September 6, 2007 Share Posted September 6, 2007 This should help LINK TO PDF {rant on} I hate poorly formed documents like this where the text immediately under a picture doesn't pertain to that picture but the one on the following page. Especially in a case like this where there is little text, plenty of page space and no reason to be as such. Just an unnecessarily bad layout. I suspect it must have been one big html or something that was printed to PDF. {rant off} Quote Link to comment Share on other sites More sharing options...
