atari5200dude Posted September 3, 2007 Share Posted September 3, 2007 does the 400 computer use a GUI? If it uses text only how hard is it to learn? Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 3, 2007 Share Posted September 3, 2007 does the 400 computer use a GUI?If it uses text only how hard is it to learn? No, no GUI. What I found: The Atari 400 boots-up into "Notepad", the only built-in program. Any other programs will have to run from cassette or cartridge - this includes BASIC, or any other programming language. At least the later ones like the 600XL and 800XL had BASIC built in - with those you get a blank blue screen that says "READY." That's it. Quote Link to comment Share on other sites More sharing options...
atari5200dude Posted September 3, 2007 Author Share Posted September 3, 2007 Is the 400 a good computer? I may be getting one Quote Link to comment Share on other sites More sharing options...
Bryan Posted September 3, 2007 Share Posted September 3, 2007 Is the 400 a good computer? I may be getting one This is a good place to learn some more: http://www.atariarchives.org/ Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 3, 2007 Share Posted September 3, 2007 Is the 400 a good computer? I may be getting one This is a good place to learn some more: http://www.atariarchives.org/ An 800 would give you more memory. The 400 may be limiting. Or you could go for the 800XL. It has 64K. A 600XL could put you in the same spot as the 400 - the 600XL has only 16K. There's the XE line, too. Quote Link to comment Share on other sites More sharing options...
atari5200dude Posted September 3, 2007 Author Share Posted September 3, 2007 Is the 400 a good computer? I may be getting one This is a good place to learn some more: http://www.atariarchives.org/ An 800 would give you more memory. The 400 may be limiting. Or you could go for the 800XL. It has 64K. A 600XL could put you in the same spot as the 400 - the 600XL has only 16K. There's the XE line, too. Actually I seen a 800xl I'll look into that too but what is the best of ataris computers Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 3, 2007 Share Posted September 3, 2007 No atari 8-bit computer has a built in GUI. The ST series does. (16-bit) Quote Link to comment Share on other sites More sharing options...
atari5200dude Posted September 3, 2007 Author Share Posted September 3, 2007 if i do get an atari 400 is it worth my time? or should I get a 800xl Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted September 3, 2007 Share Posted September 3, 2007 if i do get an atari 400 is it worth my time? or should I get a 800xl If you are just wanting to get one to experiment with an Atari 8bit system and are not looking to collect, I would recommend the 800XL or 130XE since they are the most able to do whatever you may want them to do. They will be the most compatible with the most software/hardware. Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted September 3, 2007 Share Posted September 3, 2007 if i do get an atari 400 is it worth my time? or should I get a 800xl If you can get it cheap enough, a 400 is worth your time. If you want something that will play most of the 8-bit games without modification, the 800xl is a better choice. If you want to do any programming, the 800xl is a better choice since the 400 has a flat keyboard. Quote Link to comment Share on other sites More sharing options...
Scream And Fly Posted September 3, 2007 Share Posted September 3, 2007 The 400 has always been one of my favorite 8-but machines. Once expanded, it's great. I even like the membrane keyboard. Quote Link to comment Share on other sites More sharing options...
atari5200dude Posted September 3, 2007 Author Share Posted September 3, 2007 What was the modem for? Quote Link to comment Share on other sites More sharing options...
nathanallan Posted September 3, 2007 Share Posted September 3, 2007 BBS'ing, local connections, with the right code you could do pretty much the same connecting with it as you could with any modem. I haven't seen any in a long time, but you could even get email if someone had another computer set up to make it work in your dialing range(when I say dialing range, I mean if you were willing to pay long distance or got lucky and had somebody local). You can still BBS and do that stuff, but most likely it'll be long distance calling. Nathan Quote Link to comment Share on other sites More sharing options...
