+Propane13 Posted September 7, 2007 Share Posted September 7, 2007 Hi all, Let's ask a silly programming question as a warm-up exercise. Let's say I have an interrupt routine already made, and it completes with an RTI. Then, let's say that somewhere else in the code, I want to use that same interrupt code. What happens if I JSR to it, and use the RTI to get back (instead of an RTS)? Anything serious? I would assume that the 3-bytes are still pulled from the stack (status flags, plus return address), so would there be anything different with using an RTI over an RTS? Thanks! -John Quote Link to comment Share on other sites More sharing options...
Flipper Posted September 7, 2007 Share Posted September 7, 2007 Hi all, Let's ask a silly programming question as a warm-up exercise. Let's say I have an interrupt routine already made, and it completes with an RTI. Then, let's say that somewhere else in the code, I want to use that same interrupt code. What happens if I JSR to it, and use the RTI to get back (instead of an RTS)? Anything serious? I would assume that the 3-bytes are still pulled from the stack (status flags, plus return address), so would there be anything different with using an RTI over an RTS? Thanks! -John Sadly, it doesn't work. From a 6502 information site "Note that unlike RTS, RTI does NOT add one to the destination before placing it in the Program Counter (PC)". Thus, you'll end up returning to the wrong address. Also, RTS does NOT pull the processor flags, so you're stuck there too. One method which may be available to you is to use BRK, NOP. BRK is really a software interrupt, thus can be returned from via RTI. Note, when used as a software interrupt and you want to get control back to the main program, you must follow the BRK with a NOP. The pointer stored by BRK is off by one, and will skip the next byte of program code. Of course, since the BRK pointer is stored in ROM and shared with the IRQ pointer, this may get you no savings. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 7, 2007 Share Posted September 7, 2007 Well, it does work, but you have to adjust the return and stack pointer. Quote Link to comment Share on other sites More sharing options...
Flipper Posted September 8, 2007 Share Posted September 8, 2007 Well, it does work, but you have to adjust the return and stack pointer. Ok..true...you could have two entry points. One with some setup code to get the stack right, and then one for the interrupt routine. It's a little bit ow either way. Quote Link to comment Share on other sites More sharing options...
supercat Posted September 8, 2007 Share Posted September 8, 2007 (edited) Well, it does work, but you have to adjust the return and stack pointer. An alternative would be to have a JSR-style entry point at $FAxx which performed a PHP and then jumped to the interrupt routine. If $FAxx is not convenient, $F0xx could be used provided the JSR instruction was followed by a BRK (which would not be executed). Edited September 8, 2007 by supercat Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 8, 2007 Share Posted September 8, 2007 (edited) What is the point? Are you trying to save a cycle by avoiding the use of BRK in one instance? If so, the inclusion of a seperate entry point to adjust the stack won't work. How long is the interrupt? If it's not very long, it might be better just to avoid using a JSR subroutine to begin with...and code that portion directly into the main program (also saving the cycles needed to jump there and back). Edited September 8, 2007 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 8, 2007 Share Posted September 8, 2007 One way you could do it - test the "I" flag. A NMI or IRQ routine will always be called with IRQs masked. So, you'd need: IRQSTART PHA ; ; ... rest of IRQ routine here ... ; PHP PLA AND #4 BNE IRQMASKED PLA RTS IRQMASKED PLA RTI Of course, that assumes that you're not doing SEI in your main loop before calling the routine. Quote Link to comment Share on other sites More sharing options...
+batari Posted September 8, 2007 Share Posted September 8, 2007 There are several code solutions, depending on your needs. If you don't care about X and flags upon entry, you know SP != 0 or 1 and PCL of the return address <> $FF, it's really easy. (The return address can be checked at assembly, so that shouldn't be an issue.) JSRroutine PHP TSX INC $102,x IRQroutine .... RTI SP != 0 or 1 might only be known at runtime, so if that's the case, this will work: JSRroutine PHP TSX INX INX INC $100,x IRQroutine .... RTI Furthermore, if you care about X and flags, that can be worked around as well. Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted September 11, 2007 Author Share Posted September 11, 2007 Hello, The point isn't really efficiency. I've got a... hardware project where something works in one environment but not another. So, I wanted to see if I could short-circuit a call to a pre-existing ISR routine on powerup, and what it would do, as a test. -John Quote Link to comment Share on other sites More sharing options...
doppel Posted November 27, 2009 Share Posted November 27, 2009 It seems to me that fixing the return address after a BRK would be less efficient than adding a NOP after each BRK. Unless there are lots of BRK opcodes in your code. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 27, 2009 Share Posted November 27, 2009 It seems to me that fixing the return address after a BRK would be less efficient than adding a NOP after each BRK. Unless there are lots of BRK opcodes in your code. Depends. If you know the stack pointer, you just need 3 byte to correct the return address. Quote Link to comment Share on other sites More sharing options...
solo/ng Posted October 17, 2018 Share Posted October 17, 2018 Best method is to keep your routines outside of VBL, for example: VBL pha jsr the_routine pla rti so you can use it everywhere ( "the routine") Quote Link to comment Share on other sites More sharing options...
