Fort Apocalypse Posted September 8, 2007 Share Posted September 8, 2007 (edited) Player 3 disappears when using multisprite kernel and you move it too far to the right horizontally. If you move it to the left, it is no problem. Wierd! Attached is bin that shows this bug in Stella. (Who knows- maybe it is a stella problem?) Leave paddle emulator off (so paddles all = 0) and try the following (this is not a working game - for now it is just a demo of the strange behavior). I actually get it while in both (r/l) paddle mode (but for some reason no paddles work for me still). Also, flickering seems to be bad even though the players aren't on the same vertical scan line. If you have an answer for that too, it would be much appreciated! ultindy500_0.1.basultindy500_0.1.bin Edited September 8, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 8, 2007 Author Share Posted September 8, 2007 (edited) Note I'm using Stella 2.3.5 on Win XP and bB 1.0 (at least that is what bB README.txt says). Edited September 8, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
+batari Posted September 8, 2007 Share Posted September 8, 2007 (edited) Note I'm using Stella 2.3.5 on Win XP and bB 1.0 (at least that is what bB README.txt says). Yikes! Scared me for a while there, hoping there wasn't a bug in the flickering routine (that is, other than the known bugs that are already there ) I think the problem lies here: if paddle < 38 then p3x =p3x - 1 : if p3x < 28 then p3y = 140 I'm pretty sure you want p3x = 140 at the end of that line. p3y=140 would move the third car off of the visible screen. Edited September 8, 2007 by batari Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 8, 2007 Author Share Posted September 8, 2007 Note I'm using Stella 2.3.5 on Win XP and bB 1.0 (at least that is what bB README.txt says). Yikes! Scared me for a while there, hoping there wasn't a bug in the flickering routine (that is, other than the known bugs that are already there ) I think the problem lies here: if paddle < 38 then p3x =p3x - 1 : if p3x < 28 then p3y = 140 I'm pretty sure you want p3x = 140 at the end of that line. p3y=140 would move the third car off of the visible screen. Doh! Thanks for catching that. Man I suck. Thanks, Batari! Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted September 8, 2007 Share Posted September 8, 2007 Also, flickering seems to be bad even though the players aren't on the same vertical scan line. If you have an answer for that too, it would be much appreciated! Last question first-- your car sprites have 2 blank lines at the top and bottom. Take those out, so the cars are only 4 lines tall. Then change the p2y, p3y, p4y, and p5y variables so they're 6 lines apart, because you need at least 2 blank lines between sprites to keep them from flickering-- even if some of the lines are blank. Leave paddle emulator off (so paddles all = 0) and try the following (this is not a working game - for now it is just a demo of the strange behavior). I actually get it while in both (r/l) paddle mode (but for some reason no paddles work for me still). I think your problem with the paddles is that you're using the multisprite kernel, and readpaddles is a kernel option, but none of the kernel options work with the multisprite kernel. Player 3 disappears when using multisprite kernel and you move it too far to the right horizontally. If you move it to the left, it is no problem. Wierd! Attached is bin that shows this bug in Stella. (Who knows- maybe it is a stella problem?) This might be related to the paddles, since you can't use the paddles with the multisprite kernel yet, and you're trying to use the paddles to control the movements of the sprites. Michael Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 8, 2007 Author Share Posted September 8, 2007 (edited) Awesome! Thanks, Michael! I saw Batari had posted about my bug in the player 3 y coordinate setting that was causing it to "disappear" (go off the screen) also. Edited September 8, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
