+Propane13 Posted September 12, 2007 Share Posted September 12, 2007 Hi everyone, So, I was thinking about it this morning... should there be a few standard things that occur before turning on interrupts? Let me make an example. Let's say that you enable interrupts right away (CLI). Then, you start doing some game calculations before starting anything having to do with DMA. If you do this, and DMA activates, is it perceivable that the DMA will look to an unitnitialized DPPH/DPPL, and use some random default value, thereby pointing to some random location for graphics (as there is no real DLL), that could then spider off forever (i.e. what happens if one of the random DLL's has the interrupt bit set, so it goes to the IRQ vector before it's supposed to be used)? I was wondering first, if this is a plausible scenario (i.e. you could randomly experience big problems based on where DMA cycling is on powerup). If so, maybe there should be some "safe procedures". 1) SEI 2) Set up DLL in RAM 3) Set up DL's in RAM 4) Initialize any RAM used by Interrupts 5) CLI -- THEN do calculations. I'm curious about opinions. I may be way off base with the theory here. -John Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted September 12, 2007 Author Share Posted September 12, 2007 And... I answered my own question. I forgot that you can disable DMA on the CTRL register. So, that's what you need to do initially before DLL's are set up. It's been about 4 years since I looked at any 7800 code, so please forgive my inquisitiveness. It'll all come back, I'm sure. -John Quote Link to comment Share on other sites More sharing options...
doppel Posted November 30, 2009 Share Posted November 30, 2009 Display list interrupts use NMI, not IRQ. :-) Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 3, 2009 Share Posted December 3, 2009 They also only happen when you have a DLL around to trigger them. Quote Link to comment Share on other sites More sharing options...
