Fort Apocalypse Posted September 28, 2007 Share Posted September 28, 2007 Can anyone see what I'm doing wrong that is causing the player sprite to go nuts instead of using the direction I give it? It is almost like the cars are possessed. and unfortunately the game is not "Christine". TIA! ultindy500_0.2.basultindy500_0.2.bas.bin Note the balls at the bottom are the direction (I'm dividing the direction to get the value to use for the number 1-16 player definition to use for each car) Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 29, 2007 Author Share Posted September 29, 2007 In case anyone needs it to compile here is the player scores minikernel: http://www.atariage.com/forums/index.php?s...t&p=1371092 Quote Link to comment Share on other sites More sharing options...
MausBoy Posted September 29, 2007 Share Posted September 29, 2007 I've read through the code and all I got from it was a headache. I can sort of follow it, but it seems to me that there would be a much, much easier way to go about it. Sorry I can't be any help, but honestly I never would have gotten as far as you have. Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 29, 2007 Author Share Posted September 29, 2007 I've read through the code and all I got from it was a headache. I can sort of follow it, but it seems to me that there would be a much, much easier way to go about it. Sorry I can't be any help, but honestly I never would have gotten as far as you have. I fixed the problem. I was doing some messed up stuff in player definition. I was afraid that my code sucked. Now I know. I had started to add comments in the code, but then the code got so long, and it was easier for me to read it when it was short. If I didn't have to use temp variables for everything (if I had more vars) it might be easier to read. I should also just use dim to alias the temps to make it more straightforward, but I'd be afraid I or someone else might think that those vars actually store something that isn't temporary. Please let me know how I can better write it to make more sense. Quote Link to comment Share on other sites More sharing options...
CurtisP Posted September 29, 2007 Share Posted September 29, 2007 I should also just use dim to alias the temps to make it more straightforward, but I'd be afraid I or someone else might think that those vars actually store something that isn't temporary. You could prefix the variable names with tmp, which would identify them as temporary. Quote Link to comment Share on other sites More sharing options...
MausBoy Posted September 29, 2007 Share Posted September 29, 2007 (edited) I like the way you've written it, it's very clean and well done. It's just over my head. I'm way over trying to fit stuff into 4k and the standard kernel, so my usual suggestion will probably be to use bankswitching and the superchip. Those extra 40+ variables sure make things a lot more interesting. Plus then you get a whole extra bank for level designs and whatever else. Edited September 29, 2007 by MausBoy Quote Link to comment Share on other sites More sharing options...
lord_mike Posted September 29, 2007 Share Posted September 29, 2007 Your code doesn't suck...but the lack of definitions for the temp variables also left me with a headache... and you'll be getting a killer migraine if you return to this project six months from now... Comment and do the dim-ing with the temp prefix as suggested earlier... It will not only help you, it will help us significantly when we assist you with the coding... I am especially interested in how you determine the deltas for X and Y based on direction, but again... I needed to take a break 'cos without a scorecard, it was just getting too lost with all the temp variables... Other than that, you've done a good job.. nice use of gosubs to make more structured code... and the game runs... I'm still having trouble driving the car, but at least I can actually influence its direction now! Thanks, Mike Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted September 29, 2007 Author Share Posted September 29, 2007 (edited) I'm still having trouble driving the car, but at least I can actually influence its direction now! Thanks, Mike Mike, Thanks for the suggestions! I'll definitely make sure I go back and add in some more dims and comments like you said. Let me know how you'd like the driving action to change (if you think it should react faster, etc.) and it would be totally awesome if you could try it out with real paddles and let me know (unless you just did- in that case I want to know every detail!). Edited September 29, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
