PacManPlus Posted October 6, 2007 Share Posted October 6, 2007 Hi: I am programming in bBasic for the first time, taking each stop one at a time. I am (at this point) just trying to display a playfield using the multisprite kernel, and I am getting a weird error. First, here is my code so far: set kernel multisprite set smartbranching on set tv ntsc set romsize 4k set kernel_options pfcolors pfheight=1 const screenheight=80 mainroutine playfield: XXXXXXXXXXXXXXXX ................ ................ ................ ................ ................ XXXXXXXXXX...XXX ................ ................ ................ ................ ................ XXXXXXX...XXXXXX ................ ................ ................ ................ ................ XXXX...XXXXXXXXX ................ ................ ................ ................ ................ XXXX...XXXXXXXXX ................ ................ ................ ................ ................ XXXXXX...XXXXXXX ................ ................ ................ ................ ................ XXXXXXXXX...XXXX ................ ................ ................ ................ ................ XXXXXXXXXXXXXXXX ................ end COLUBK=6 pfcolors: 66 134 134 134 134 134 66 66 66 66 66 66 66 66 66 66 66 66 66 28 28 28 28 28 66 66 66 66 66 66 66 66 66 66 66 66 66 200 200 200 200 200 66 end drawscreen goto mainroutine and this is the error I'm getting: 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left --> cycle74_HMCLR f084 Of course, the bin doesn't run (it crashes), so I'm trying to figure out what I did wrong... can anyone see anything obvious? Thanks in advance, Bob Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 6, 2007 Share Posted October 6, 2007 I am programming in bBasic for the first time, taking each stop one at a time. I am (at this point) just trying to display a playfield using the multisprite kernel, and I am getting a weird error. 2600 Basic compilation complete.DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left --> cycle74_HMCLR f084 That particular message is more of a warning than an error, and it won't keep your program from running. Basically, it means that the address of the line label "cycle74_HMCLR" changed while DASM was assembling your program, between one pass and another pass. That's actually a pretty normal thing to have happen, because it normally takes an assembler two or three passes through the code to resolve the addresses of all the labels. However, when I compile your program, I get a different message, one which indicates a real problem-- namely, that you're trying to use the pfcolors kernel option with the multisprite kernel. Unfortunately, none of the kernel options will work with the multisprite kernel. So you should out everything related to the pfcolors kernel option. I've also removed the tv and romsize statements, because you're setting them to the default values, hence you can omit them (or you can leave them in if you prefer; it won't make any difference). set kernel multisprite set smartbranching on pfheight=1 const screenheight=80 mainroutine playfield: XXXXXXXXXXXXXXXX ................ ................ ................ ................ ................ XXXXXXXXXX...XXX ................ ................ ................ ................ ................ XXXXXXX...XXXXXX ................ ................ ................ ................ ................ XXXX...XXXXXXXXX ................ ................ ................ ................ ................ XXXX...XXXXXXXXX ................ ................ ................ ................ ................ XXXXXX...XXXXXXX ................ ................ ................ ................ ................ XXXXXXXXX...XXXX ................ ................ ................ ................ ................ XXXXXXXXXXXXXXXX ................ end COLUBK=6 COLUPF=66 drawscreen goto mainroutine Michael Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted October 6, 2007 Author Share Posted October 6, 2007 Thanks! That did it! Quote Link to comment Share on other sites More sharing options...
