gokmase Posted October 6, 2007 Share Posted October 6, 2007 Hi all, Following the 0.170 release in June earlier this year, there is now a new aICQ release ready for download. A good deal of small issues have been sorted out but there are a couple of additions made this time too. You can download the new release here: http://www.ataricq.org Compared to the previous official release: * A number of minor bugs sorted * In some popup menus it was not possible to select an entry in case either contact list or msg window was also open. Fixed now. * Fetching of contacts from the server side list had accidently been disabled in 0.170. It works now, but this needs to be reimplemented in the future. * Found and fixed a small bug that would result in form_wbutton() not being used under MagiC for handling of mouse clicks in background. * AtarICQ now use AV_STARTPROG instead of VA_START when: 1. Asking AV-SERVER to launch the Colour Selector (In Prefs./Contact list) 2. Asking AV-SERVER to replay sound sample files 3. Asking AV-SERVER to display history file (CTRL+H) 4. Asking AV-SERVER to display the help file (HELP)<br> (This should be good news to people who use other desktops than Thing) * A right click on an empty place in contact list will open up the popup menu with a listing of contacts, allowing you to "Create TAB for <nick>". (Also available through CTRL+T) * All popup menus that have window titles will now also have a CLOSER widget. Also, these popups can now also be moved like any other GEM window. * Using TAB or UP/DOWN-ARROW to jump to next text edit field in a dialog now works better under MagiC. SHIFT+TAB will now move focus backwards. Also, when we hit the last (or first, depending on TAB-direction) editable object of the dialog, focus will not wrap back to the first (or last) editable object. (This is in fact a workaround for MagiC's limited implementation of FORM_KEYBD) * Last AtarICQ release had a bug in the keyboard evaluation code that prevented user to type chars that required ALT-combinations. Should be OK now. * Adapted aICQ to some server changes on the ICQ-servers, making the logging in process a tad faster, and the updating of the contact list a lot smoother during it. Have fun, and please don't hesitate to send feedback! I hope there are a bunch of people out there still using the program, is that so? Smile Regards, /Joakim Quote Link to comment Share on other sites More sharing options...
