Tickled_Pink Posted October 11, 2007 Share Posted October 11, 2007 I'd like to finally try out the Atari 800 I was given a couple of years ago so that my 5 year old can have a machine with a nice keyboard in her bedroom. Only problem is that I don't have a power supply for it. I've had a look online and it says that the 800 uses a 9V AC power supply. Does this apply to PAL as well as NTSC (I see no reason why it shouldn't)? It's a bit of a bummer. Does anyone know where I can pick up a suitable PSU? I don't know much about AC power supplies. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 11, 2007 Share Posted October 11, 2007 (edited) That's right. 9 Volts AC (not DC) for the 400 and 800 (but NOT for the XLs or XEs - they use 5 Volts DC). 1.7 Amps (according to the FAQ). I think that the generic wall-warts would probably not quite be sufficient... not a good idea to use an under-rated supply, I used the 9V adaptor for my 1010 recorder to power something else once, and it took 20 minutes to cool down to the point where you could touch it. Edited October 11, 2007 by Rybags Quote Link to comment Share on other sites More sharing options...
Tickled_Pink Posted October 11, 2007 Author Share Posted October 11, 2007 Well, just been doing some digging around and according to this site the PSU output is 3.2 Amps. Is the PAL output different from the NTSC models? If it does turn out to be 3.2A then Maplins have an adapter that should do the trick nicely. Maplins AC/AC Adapters Quote Link to comment Share on other sites More sharing options...
mimo Posted October 11, 2007 Share Posted October 11, 2007 It needs at least 1 amp I believe, the maplin one would be fine, the 800 will only draw the current that it requires. Good luck Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted October 11, 2007 Share Posted October 11, 2007 Why doesn't it give the input on those? Doesn't the UK use 50 Hz? Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted October 11, 2007 Share Posted October 11, 2007 The relevant section of the 8-bit FAQ has some useful information. Quote Link to comment Share on other sites More sharing options...
Tickled_Pink Posted October 11, 2007 Author Share Posted October 11, 2007 I did post a response after reading the FAQ following mimo's post saying that the 1010 PSU should work fine - didn't go through obviously. Anyway, tried it and it does work. The 800 fires up fine, boots carts (although my previously unopened Kaboom cart seems to be a dud) but can't play them ... the START button doesn't work! What's the best way of fixing it? Quote Link to comment Share on other sites More sharing options...
mimo Posted October 12, 2007 Share Posted October 12, 2007 I would start by taking the 800 apart and having a visual check of the KB and connectors. Make sure everything is where it should be, and clean. Try some repeated pressing of the key, that sometimes helps things along. B+C do new replacements for $20 which is a bargain. Quote Link to comment Share on other sites More sharing options...
Beetle Posted October 12, 2007 Share Posted October 12, 2007 OT Would you die for an Atari?Well I will when my wife finds out that what she knows about is only the tip of the iceberg and I paid about 10 times what I told her for it. Join me and boycott Atari Age and its evil pushers of Atari filth. LOL! Mimo, great footer, just love it! /OT Greetings, Beetle Quote Link to comment Share on other sites More sharing options...
+warerat Posted October 12, 2007 Share Posted October 12, 2007 I would start by taking the 800 apart and having a visual check of the KB and connectors.Make sure everything is where it should be, and clean. Try some repeated pressing of the key, that sometimes helps things along. B+C do new replacements for $20 which is a bargain. A new keyboard doesn't apply to the 800 console keys, as they're on the power board. Quote Link to comment Share on other sites More sharing options...
