mons2b Posted October 12, 2007 Share Posted October 12, 2007 Hi a while back I removed my tos chips from my 520 STE to see if they would work in an Atari Mega (German). I now wish to put them back into the STE but I dont know which way round they go? How do I know which is the HIGH one and which is the LOW one? Also some of the pins were factory bent and I straightened them now I dont remember which ones to bend out! HELP ME! :-( Quote Link to comment Share on other sites More sharing options...
tjlazer Posted October 12, 2007 Share Posted October 12, 2007 (edited) Hi a while back I removed my tos chips from my 520 STE to see if they would work in an Atari Mega (German). I now wish to put them back into the STE but I dont know which way round they go? How do I know which is the HIGH one and which is the LOW one? Also some of the pins were factory bent and I straightened them now I dont remember which ones to bend out! HELP ME! :-( Relax a bit. As long as you install the chips with the notch in the correct way you will be fine. All you will get is a white screen. Switch off and swap chips. Don't know about the pin issue. Was not aware of any pins left out! The following link might help: http://groups.google.com/group/comp.sys.at...e60ae126e8c591c Edited October 12, 2007 by tjlazer Quote Link to comment Share on other sites More sharing options...
mons2b Posted October 12, 2007 Author Share Posted October 12, 2007 Thank you. I did as you suggested. I swapped the chips around and left all the pins straight and it booted up ok. I was just stressing because I have no spare tos chips and this is my only STE. Quote Link to comment Share on other sites More sharing options...
