Fort Apocalypse Posted October 14, 2007 Share Posted October 14, 2007 Hey, I'm doing the following at the top of my bB game: include div_mul16.asm and then at one point I do this: handleroom temp6 = proom // 10 rem *** remainder (last digit) stored in temp1 if temp1 = 1 then gosub room1 if temp1 = 2 then gosub room2 if temp1 = 3 then gosub room3 if temp1 = 4 then gosub room1 if temp1 = 5 then gosub room2 if temp1 = 6 then gosub room3 if temp1 = 7 then gosub room1 if temp1 = 8 then gosub room2 if temp1 = 9 then gosub room3 if temp1 = 0 then gosub room1 return when compiling I get the following error. Can anyone see what I'm doing wrong? I want to get the remainder of dividing proom by 10 in order to get the last digit of that number (for now it is just as proof of concept). ---------- Capture Output ---------- > "C:\Atari2600\bB\2600bas.bat" C:\Atari2600\projects\fmadventure\2padv0.3.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left --> cycle74_HMCLR f084 914 bytes of ROM space left 914 bytes of ROM space left 914 bytes of ROM space left --- Unresolved Symbol List div16 0000 ???? (R ) Fatal assembly error: Source is not resolvable. > Terminated with exit code 0. Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted October 14, 2007 Author Share Posted October 14, 2007 I've also tried including both in the top: include div_mul.asm include div_mul16.asm and then I get the error: ---------- Capture Output ---------- > "C:\Atari2600\bB\2600bas.bat" C:\Atari2600\projects\fmadventure\2padv0.3.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left --> cycle74_HMCLR f084 > Terminated with exit code 0. Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted October 14, 2007 Author Share Posted October 14, 2007 Here's the full source 2padv0.3.bas Quote Link to comment Share on other sites More sharing options...
+batari Posted October 14, 2007 Share Posted October 14, 2007 Here's the full source2padv0.3.bas You need to place includes before anything else. Particularly, if you put them after the "set" directive, they might be ignored. Hmmm.... Maybe I should have the compiler generate a warning instead? Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted October 18, 2007 Author Share Posted October 18, 2007 (edited) Here's the full source2padv0.3.bas You need to place includes before anything else. Particularly, if you put them after the "set" directive, they might be ignored. Hmmm.... Maybe I should have the compiler generate a warning instead? Thanks! That was definitely it. Yes, it would be great to have a compiler warning if it's not too hard. The more compilation warnings the better, IMO. Edited October 18, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
