devwebcl Posted October 19, 2007 Share Posted October 19, 2007 (edited) Hello, Once again playing with cc65 & Text Adventures I was able to port ScottFree The problem is after compilation the memory left is to small, therefore all the games run out of memory, however there is a small adventure called Cloak Adventure small enough to be ported to different Text Adventure dialects (It's similar to a Hello World ) The game can be downloaded from http://devweb.cl/atari/cc65/cloak.xex As you can see it's a very alpha release, where there is no layout control (as usually in this kind of games). The final idea was to see something with this Parser to compiled and functional in the a8. Regards, Devwebcl Edited October 19, 2007 by devwebcl Quote Link to comment Share on other sites More sharing options...
JamesD Posted October 20, 2007 Share Posted October 20, 2007 (edited) If you can convert the I/O so that it bypasses stdio you'll save several K of RAM. You might check to see if any of the other 6502 compilers generate smaller code. You might also try starting with this interpreter instead. http://www.ifarchive.org/if-archive/scott-...ree/scottzx.zip Edited October 20, 2007 by JamesD Quote Link to comment Share on other sites More sharing options...
devwebcl Posted October 20, 2007 Author Share Posted October 20, 2007 If you can convert the I/O so that it bypasses stdio you'll save several K of RAM. You might check to see if any of the other 6502 compilers generate smaller code. You might also try starting with this interpreter instead. http://www.ifarchive.org/if-archive/scott-...ree/scottzx.zip Thanks for the tip, anyway I'm using ScottFree, the one you mention is a version for ZX of it, but I have compared the code and the difference is most about the printing of information (about layout) and load/save feature, but I don't see any improvement about data structure or else. I think the big problem is the atari free memory and perhaps the heuristics of cc65 for optimization, however is great compiler, thus I think the TODO is to implement a compression algorithm for the data. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 20, 2007 Share Posted October 20, 2007 (edited) I'm using the original interpreter (well the one from the value packs) and relocating it to run from RAM after loading from ROM and that is fitting fine in 8K. I use CA65 and LD65 to build a cart image and this also contains the game data for titles 1-12 which is accessed at runtime as required, a menu to select which game you want to play and the original script font. A game at runtime can now run in 16K Certainly your overheads of C->asm, use of heap/stack and the need for support of the runtime libraries when building ScottFree are probably too great, I tried a similar thing before with the ITF infocom interpreter for the Atari ST, building it under CC65, for me I think the approach is to come up with a method of putting segment code in separate banks and have a 'far' call type way of swapping between then, say a subroutine/function jump table in RAM. Regards, Mark Edited October 20, 2007 by Wrathchild Quote Link to comment Share on other sites More sharing options...
devwebcl Posted October 22, 2007 Author Share Posted October 22, 2007 ....Certainly your overheads of C->asm, use of heap/stack and theneed for support of the runtime libraries when building ScottFree are probably too great, I tried a similar thing before with the ITF infocom interpreter for the Atari ST, building it under CC65, Do you have a final executable of that porting, or did you have the same problems than me? (to run out fo memory). I think the approach is to come up with a method of putting segment code in separate banks and have a 'far' call type way of swapping between then, say a subroutine/function jump table in RAM. Regards, Mark Do you know where I can find more information of segments rearrangement in memory banks? I found something in the compiler documentation, but I it wasn't very clear. Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted October 28, 2007 Share Posted October 28, 2007 What are looking to do with segment rearrangement, devweb? You could put your subroutine/jump table in LOWCODE (use #pragma codeseg("LOWCODE") ) and that will insure that your jumptable code is below the extended RAM window ($4000), as long as you are using the default linker config. I'm doing that in one of my programs that automatically switches in BASIC (which would overwrite some of the program, not to mention the default display list and screen ram.) Quote Link to comment Share on other sites More sharing options...
devwebcl Posted October 30, 2007 Author Share Posted October 30, 2007 What are looking to do with segment rearrangement, devweb? You could put your subroutine/jump table in LOWCODE (use #pragma codeseg("LOWCODE") ) and that will insure that your jumptable code is below the extended RAM window ($4000), as long as you are using the default linker config. I'm doing that in one of my programs that automatically switches in BASIC (which would overwrite some of the program, not to mention the default display list and screen ram.) thanks for the help , I'll take a look to it. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 31, 2007 Share Posted October 31, 2007 Sorry for the delay in replying, I wanted to experiment a bit with a cart model switching example which I've posted on the programming forum for further discussion on it there. It certainly ain't pretty, but does give some idea as to how this can be done (in this case using the XEGS model). Regards, Mark Quote Link to comment Share on other sites More sharing options...
