LS_Dracon Posted October 30, 2007 Share Posted October 30, 2007 (edited) First, a look in "standard" repositioning code : ;----------------------- lda P0_XPos;Load desired position ldx #0 ; Clean X jsr SetXPos ;Jump to repositioning code ;------------------------- ... sta WSYNC sta HMOVE ... ;------------------------------------------ SetXPos;SUBROUTINE ;------------------------------------------ sec sta WSYNC WaitObject: sbc #$0f; 2 bcs WaitObject; 2³ waste cicles eor #$07; 2 adjust nibble asl; 2 shift bites for correct HMXX value asl; 2 asl; 2 asl; 2 sta HMP0,x; 4 store in HMXX (fine adjust) sta.wx RESP0,x ; 5 Then Reset Position rts; Return to code ;----------------------------------------------- This code you set position for P0. For others objects you need create another loop and RESXX again. I made some motiffications, and here's the code : ;----------------------- lda P0_XPos;Load desired position jsr SetXPos ;Jump to repositioning code sta RESP0;But repositioning when return sta HMP0 ;The loop can be used for all objects ;------------------------- ... ;------------------------------------------ SetXPos ;------------------------------------------ sec sta WSYNC WaitObject: sbc #$0f bcs WaitObject eor #$07 asl asl asl asl rts ;Return without sta RESXX ;----------------------------------------------- Note, this code you don't need ldx #0. So all players can use only 1 loop code for repositioning : ;----------------------- lda P0_XPos;Repositioning P0 jsr SetXPos sta RESP0 sta HMP0 ;----------------------- lda P1_XPos;Repositioning P1 jsr SetXPos sta RESP1 sta HMP1 ;------------------------- lda M0_XPos;Repositioning Missile0 jsr SetXPos sta RESM0 sta HMM0 ;------------------------- lda M1_XPos;Repositioning Missile1 jsr SetXPos sta RESM1 sta HMM1 ;------------------------- lda BL_XPos;Repositioning Ball jsr SetXPos sta RESBL sta HMBL ;-------------------------- sta WSYNC sta HMOVE ... ;------------------------------------------ SetXPos ;SUBROUTINE ;------------------------------------------ sec sta WSYNC WaitObject: sbc #$0f bcs WaitObject eor #$07 asl asl asl asl rts;Return That is. Tested and work in emulators and real hardware. The standard code I copy from one demo posted here by Thomas Jenzsch. Probably have similar codes, but I never saw, so I decide share this code. Edited October 31, 2007 by LS_Dracon Quote Link to comment Share on other sites More sharing options...
Robert M Posted November 3, 2007 Share Posted November 3, 2007 Hi, Your code is correct, but I believe you are misunderstanding the usage of the X register in the original code. The purpose of X is to select the object you want to position horizontally. (0=P0, 1=P1, 2=M0, 3=M1, 4=Ball). So if you want to position M1 say with the original routine you would fo this: LDA M0xPos LDX #3 ; 3=M0 JSR SetXpos You can do the same thing for the other 4 objects. Just as you did in your modified code. So you can use the exact same routine to position all 5 objects. As an added bonus, if you arrange your object X positions in consecutive memory locations in RAM you can use a small loop to position them all like this: ObjectArray EQU $80 P0xPos EQU $80 P1xPos EQU $81 M0xPos EQU $82 M1xPos EQU $83 BallXpos EQU $84 PositionAllObjects LDX #4 ; Start with the Ball and count downwards. .positionLoop LDA ObjectArray,X ; Use indexed addressing to read the X pos of the next object to be repositioned. JSR SetXpos ; Position object X DEX ; Decrement X to point at next object BPL .positionLoop ; While X >= 0 go to the top of the loop. STA WSYNC STA HMOVE ; Apply the fine adjustment for all 5 objects. RTS ; All 5 objects are positioned. The original code uses Indexed addressing with the X register to allow a simple loop to position any or all of the objects. Cheers! Quote Link to comment Share on other sites More sharing options...
LS_Dracon Posted November 3, 2007 Author Share Posted November 3, 2007 I think X was used to waste 1 cicle. Tnx for sharing this optimized code Quote Link to comment Share on other sites More sharing options...
