PacManPlus Posted November 20, 2007 Share Posted November 20, 2007 Hi: I have two NES Famiclone Light Guns (they use a DB-9 Male connector with pins 1,5,6, and 8 used). Is there a way to re-wire this gun for the 7800? I can probably pick out where the +5v and GND wires go (once I open it up), but the other two might be a little difficult. Has anyone done this? Thanks! Bob Quote Link to comment Share on other sites More sharing options...
Shawn Posted November 20, 2007 Share Posted November 20, 2007 (edited) I forget how to do it but so you know your not tinkering in vien yes it can be done. EDIT: I'm pretty sure fire is the trigger and up direction is the strobe. Edited November 20, 2007 by Shawn Sr. Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted November 21, 2007 Author Share Posted November 21, 2007 (edited) Thanks, Shawn Judging from this photo, can anyone tell me which color wires go to which pins? Thanks in Advance Bob (As you can tell, I am not familiar with the inner workings of the light gun) Edited November 21, 2007 by PacManPlus Quote Link to comment Share on other sites More sharing options...
Shawn Posted November 21, 2007 Share Posted November 21, 2007 Thanks, Shawn Judging from this photo, can anyone tell me which color wires go to which pins? Thanks in Advance Bob (As you can tell, I am not familiar with the inner workings of the light gun) I need a pic of the componant side also please. Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted November 21, 2007 Author Share Posted November 21, 2007 (edited) Hey Shawn: Heh - I had a feeling I would need the other side - I had planned on taking a pic when I got home from work tonight (that pic is from the internet, but it's exactly the same as what I have) EDIT - Picture Added Thanks! Bob Edited November 21, 2007 by PacManPlus Quote Link to comment Share on other sites More sharing options...
Shawn Posted November 25, 2007 Share Posted November 25, 2007 (edited) Hey Shawn: Heh - I had a feeling I would need the other side - I had planned on taking a pic when I got home from work tonight (that pic is from the internet, but it's exactly the same as what I have) EDIT - Picture Added Thanks! Bob I'll have a stab at this on the weekend when I get some time. I'll just do one up myself and report back the results. EDIT: Whats the rating on that cap? Edited November 25, 2007 by Shawn Sr. Quote Link to comment Share on other sites More sharing options...
Foxsolo2000 Posted November 25, 2007 Share Posted November 25, 2007 Hope you succeed Shawn, wouldn't mind getting one of you myself Quote Link to comment Share on other sites More sharing options...
mimo Posted December 2, 2007 Share Posted December 2, 2007 Did this work? can someone post a how to? Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 2, 2007 Share Posted December 2, 2007 Here's a pinout for the thing on Ben Heck's forums: http://forums.benheck.com/viewtopic.php?t=...perjoy+lightgun Never done one myself, though. Quote Link to comment Share on other sites More sharing options...
thomasholzer Posted December 2, 2007 Share Posted December 2, 2007 There's an (very late) Antic issue explaining to work the NES Zapper with XEGS Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted December 3, 2007 Author Share Posted December 3, 2007 Hi: Thanks guys, but unfortunately that thread isn't going to help me. I stupidly had cut the connector end off a while ago so I don't know which pin goes to which wire. That is why I posted the picture above, about which wire is which signal. Thanks anyway, Bob Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 3, 2007 Share Posted December 3, 2007 Based on the pictures (the first set are rather small), I'd guess this: 2600/7800 Port (light-gun) Pin 1 -- Trigger Brown (sure of this one) Pin 6 -- Light Sensor Blue ?? Pin 7 -- +5V Red ?? Pin 8 -- Gnd Yellow ?? I'm sure of the Brown wire being trigger -- but the others not so sure. If you can determine which are ground & +5v than I only leaves one possiblity for the light sensor. That red wire that runs from the board to the trigger switch should be hooked to the ground wire, so that might give you a clue for the ground connection. Also, if you get it working and the gun fires when you release the trigger instead of when pulling it, move that red wire on the trigger switch to the other (unused connector) to fix it. Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted December 7, 2007 Author Share Posted December 7, 2007 (edited) Ok - I tried both light guns I had. All I was ever able to do was get the trigger to function. I even tried reversing pins 6 and 7 - never registered a hit either way, even putting the gun point blank on the target on the screen. (BTW I was using Sentenel as a test) I think it's safe to assume that the famiclone guns do not work on the 7800. I've saved everyone the trouble by ruining two guns on the process. Edited December 7, 2007 by PacManPlus Quote Link to comment Share on other sites More sharing options...
