Phantom Posted December 23, 2007 Share Posted December 23, 2007 you can plug an NES pad into one end and connect an atari 2600 extension cable to the other end and hence use the NES pads on a 2600??? Can it be made? I have a NES pad that is modded for the 2600 and I will be usuing it all the time now. Made Colecovision so easy to play tonight with my keypad adapter. But Id love to be able to connect any NES Pad to a 2600 and such. I figure eventually I may waer out that nes pad and it would be neat to have such a device. I figure it would be the size of those autofire/hyper fire adapters that just go on the end of any cx40. I dont even know if this is the right place to bring it up but I figured I'd mention it. Now the crafty people run with it! Cheers Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted December 23, 2007 Share Posted December 23, 2007 I believe you can use a Sega Master System control pad on a 2600 without modification. Quote Link to comment Share on other sites More sharing options...
ckrtech Posted December 23, 2007 Share Posted December 23, 2007 Hi, Phantom. It is possible to connect a NES controller to an Atari 2600, however it will require an internal modification of the NES controller (connect wires to your 9 pin plug for the 2600) The NES controller "communicates" with its system in a different way than the 2600/Genesis/SMS do with their systems. It can definitely be done. It just requires more modification than an external pin conversion. Quote Link to comment Share on other sites More sharing options...
Atari-Jess Posted December 23, 2007 Share Posted December 23, 2007 The NES has a small IC inside the controller which makes such a connector foolishly pointless when you could just use a Genesis controller or yes, a Master System controller. Either crack open the NES controller and hack it, or use the Genny controllers, otherwise forget the converter. Quote Link to comment Share on other sites More sharing options...
Phantom Posted December 23, 2007 Author Share Posted December 23, 2007 OK well it sounds like its too much of a problem and I laready own a NES one I can use with my 2600 like I stated above. I bought it modded. The connector sounds like it wouldnt work because of the setup of the NES wiring. So thanks, you answered my question. Happy Hols. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted December 24, 2007 Share Posted December 24, 2007 (edited) It isn't just the wiring; the NES controller is considered a "smart" device. It stores the user inputs and then sends them as a serial data stream when requested by the console. See this link: Nintendo NES and SNES joystick controller pinout. By comparison, 2600 joysticks and 2-button Genesis pads are simple "dumb" devices which only consist of switches and wires. To make an adapter which lets a VCS console see an unmodified NES pad as a 2600 joystick, you would have to build an electronic converter box which reverses this process, essentially communicating with the NES pad in the same way that a NES console would, and translating the output into "Atari" signals. To have someone like me build this for you would cost much more than just getting yourself a 2-button Genesis pad. On the other hand, if you're an electronics hobbyist who likes doing "pointless" projects or doing things the hard way, I'm sure some of us would enjoy reading a write-up of such a project if you should decide to build one. Edited December 24, 2007 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 24, 2007 Share Posted December 24, 2007 Unless you wear out the PCB you could replace the rest of the parts even the shell. The PCB is the only thing modified. Quote Link to comment Share on other sites More sharing options...
Phantom Posted December 24, 2007 Author Share Posted December 24, 2007 On the other hand, if you're an electronics hobbyist who likes doing "pointless" projects or doing things the hard way, I'm sure some of us would enjoy reading a write-up of such a project if you should decide to build one. This post has been edited by A.J. Franzman: Today, 3:04 AM Im an idea man! Im all thumbs LOL! Yea I'll just use th Genny controller if this one takes a crap on me eventually. IM a bit of a controller nut. I have so many different joys for the CV and atari, I dont have time to use them all and Im always trotting out a new one it seems. I think I'l just stick to my favorites. I even have that Joysensor, thats a neat controller for the CV. The NES one just fits so nicely in ones hand. I havent broken out my Genny in a long time. I have tried the controller once just to see because I didnt know it worked til about 2 years ago. I never heard of it til I saw it on a post here. Im gonna break out the Genny controller and give it a whirl. Thanks gang. Merry Christmas Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 25, 2007 Share Posted December 25, 2007 The Genny pads work fine on the 2600, but I'm not sure about the CV. I tried one out once and it does weird things like starting a game when you push the directional. I decided not to use it as I was afraid it would blow the CV controller ports. Quote Link to comment Share on other sites More sharing options...
ravenxau Posted January 3, 2008 Share Posted January 3, 2008 It isn't just the wiring; the NES controller is considered a "smart" device. Just another example of why nintendo make things more complex than they need to be. Trying to re-invent the wheel Quote Link to comment Share on other sites More sharing options...
+warerat Posted January 4, 2008 Share Posted January 4, 2008 you can plug an NES pad into one end and connect an atari 2600 extension cable to the other end and hence use the NES pads on a 2600??? Can it be made? I have a NES pad that is modded for the 2600 and I will be usuing it all the time now. Made Colecovision so easy to play tonight with my keypad adapter. But Id love to be able to connect any NES Pad to a 2600 and such. I figure eventually I may waer out that nes pad and it would be neat to have such a device. I figure it would be the size of those autofire/hyper fire adapters that just go on the end of any cx40. I dont even know if this is the right place to bring it up but I figured I'd mention it. Now the crafty people run with it! Cheers It can be done without hacking the controller, but you'll need a small circuit. I immediately thought about a 74HC595, but I found this article. The article is in Spanish, but the schematic should be self-explanatory. http://es.geocities.com/gamemasterquilpue/NESPAD2ATARI.htm Quote Link to comment Share on other sites More sharing options...
