AtariKen64 Posted July 31, 2002 Share Posted July 31, 2002 what the differnce between atari anniversary for dreamcast and atari anniversary redux for playstaion? what s the redux what IS a redux? will the atari forever (title?) 3d remake game ever make it to playstaion ? or doomed to be stuck on pc forever?? Quote Link to comment Share on other sites More sharing options...
Agent X Posted August 5, 2002 Share Posted August 5, 2002 I don't have a Dreamcast , so I can't comment on that version of Atari Anniversary Edition. I do have Atari Anniversary Edition for the PC, as well as Atari Anniversary Edition Redux for PlayStation, so I'll compare those two. Atari Anniversary Edition for PC has the following 12 games (in alphabetical order): Asteroids Asteroids Deluxe Battlezone Centipede Crystal Castles Gravitar Millipede Missile Command Pong Super Breakout Tempest Warlords I think the Dreamcast version has the same 12 games. Atari Anniversary Edition Redux for PlayStation has 12 games also, but Crystal Castles and Millipede are not included. Taking their place are Black Widow and Space Duel. The change in the two games is probably the most obvious difference. Another difference that's not quite so obvious is in the control methods used. The PC gives you a choice of keyboard, mouse, or joystick, so you can use whatever works best for you. The PlayStation version supports the basic digital joypad, but if you have a Dual Shock controller for the PlayStation, then most of the games can also be played using analog control. Certain games such as Battlezone and Black Widow benefit greatly from the use of the two thumbsticks. The PlayStation mouse is also supported for games that used a Trak-Ball or paddle in the arcade. I have a Nyko Classic Trackball, which is functionally equivalent to the mouse, and it works great! The PlayStation version also supports the Multitap, so you can get some four-player Warlords going. In addition to the low-resolution (320x240) graphics mode for all games, the PlayStation version supports medium-resolution (640x240) and high-resolution (640x480) for the vector games. The PC version can support much higher resolutions; the vector games look absolutely incredible on the PC with anti-aliasing, and the raster games have scanlines to simulate that old arcade monitor appearance. Both packages are under $15 each. Unless you're really strapped for cash, I recommend buying both! Quote Link to comment Share on other sites More sharing options...
someguy Posted August 5, 2002 Share Posted August 5, 2002 There's an Atari Anniversary cart for the GBA. I think it has Asteroids, Missile COmmand, Tempest, and a couple of other Atari games on it. Is it any good? Quote Link to comment Share on other sites More sharing options...
AtariKen64 Posted August 17, 2002 Author Share Posted August 17, 2002 the atari revival was the name i was thinking of, not atari forever, but sort of sound the same. anyways. i hope that gets put on the playstation some time soon. Quote Link to comment Share on other sites More sharing options...
