RSS Bot Posted January 1, 2008 Share Posted January 1, 2008 Figured out why the fast forward stopped working. Also found what I think to be a bug in the 2.03 code. Seems they moved alot of loop code that was in main.c over into atari.c. Problem is the loop that worked by default in main.c don't work so well in a called function. So I modified it and finally got it working. Although I think I might be using it outside of it's intended use. Ah well. http://www.atariage.com/forums/index.php?a...;showentry=4334 Link to comment Share on other sites More sharing options...
