attf55 Posted August 2, 2002 Share Posted August 2, 2002 I need to know if anyone can give me the rating for an Atari 2600 power supply, so i can re-create one for mine. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 2, 2002 Share Posted August 2, 2002 DC 9V 500 mA, center positive. Mitch http://atari7800.atari.org Quote Link to comment Share on other sites More sharing options...
eggplant_casserole Posted August 30, 2002 Share Posted August 30, 2002 REGULATED!!!! Quote Link to comment Share on other sites More sharing options...
DanBoris Posted August 30, 2002 Share Posted August 30, 2002 Actually, the AC adaptor is un-regulated, the voltage regulator is inside the system. Just be sure your adaptor is rated at 9VDC and a minimum oif 500ma, and make sure the tip of the plug is positive and you should be ok. Dan Quote Link to comment Share on other sites More sharing options...
eggplant_casserole Posted August 31, 2002 Share Posted August 31, 2002 mm, good point - it was late! altho i've seen a machine over here that requires a regulated psu Quote Link to comment Share on other sites More sharing options...
