Lynxer Posted January 14, 2008 Share Posted January 14, 2008 Hi All I am following Bjoern Spruck's Lynx Programming for Dummies tutorial and I am trying to assemble the "Hello World" example (assembly version) as given in Chapter 4. This example is also provided separately as "hallo_a.asm" in a .zip archive along with the tutorial. I've changed the path references in this source file to match my environment as necessary. However, when I try to use LYXASS to assemble the file, it fails with a Syntax error on lines 38,39 and 41,45. These lines are: - BEGIN_ZP END_ZP BEGIN_MEM END_MEM I am using a command prompt under Windows XP and the command line I am using is: - lyxass hallo_a.asm I think that the problem is that the LYXASS that I am using is the wrong one, it states "tjass/lyxass C-version V0.47". If this is the cause of my problem, please can someone advise where to get a version of lyxass that works with assembly source? Thanks Robin Quote Link to comment Share on other sites More sharing options...
sage Posted January 14, 2008 Share Posted January 14, 2008 BEGIN_ZPEND_ZP BEGIN_MEM END_MEM These are macros which you have to include first. * include macros path "c:\lynx\alles" include <hardware.asm> include "help.mac" Quote Link to comment Share on other sites More sharing options...
Lynxer Posted January 15, 2008 Author Share Posted January 15, 2008 BEGIN_ZPEND_ZP BEGIN_MEM END_MEM These are macros which you have to include first. * include macros path "c:\lynx\alles" include <hardware.asm> include "help.mac" Hi sage, thanks for your reply. However, these macros are already referenced (although in a different path) and are present in the c:\lynx\bll\macros directory. The macro definition in the code I am trying to assemble is: * macros path "c:\lynx\bll\macros" include <hardware.asm> include "help.mac" include "if_while.mac" include "font.mac" include "window.mac" include "mikey.mac" include "suzy.mac" include "irq.mac" include "debug.mac" path and the syntax errors still persist... C:\LYNX>lyxass hallo_a.asm hallo_a.asm: 38:ERROR: Syntax Error ! hallo_a.asm: 39:ERROR: Syntax Error ! hallo_a.asm: 41:ERROR: Syntax Error ! hallo_a.asm: 45:ERROR: Syntax Error ! Code-size : 2046 Lines : 3736 Macros expanded : 63 Pass 2 runs : 113 Start-address : $21f0 Memory usage : 1129948 Total Errors :4 No file written ! C:\LYNX> I have attached the entire example to this post. This is identical to Bjoern's original except that I have changed the paths to the resource files as necessary for my installation. Thanks for any further assistance you can offer... perhaps I am too much of a dummy for Bjoern's tutorial..? hallo_a.txt Quote Link to comment Share on other sites More sharing options...
+karri Posted January 15, 2008 Share Posted January 15, 2008 include <hardware.asm> What is hardware.asm? I compiled your code with lyxass without problems by removing hardware.asm and hallobm2.spr (as you did not include it). The code is OK in my opinion. -- Karri Quote Link to comment Share on other sites More sharing options...
Lynxer Posted January 15, 2008 Author Share Posted January 15, 2008 include <hardware.asm> What is hardware.asm? I compiled your code with lyxass without problems by removing hardware.asm and hallobm2.spr (as you did not include it). The code is OK in my opinion. -- Karri I don't know what hardware.asm is and it's not *my* code! I'm following the tutorial because, although I am an experienced assembly programmer (with various micros but not 6502) I wanted to learn something about programming for the Lynx. I was hoping I could start with a simple "Hello World" example... I've also tried removing hardware.asm and hallobm2.spr but I still get the syntax errors on the four lines as before. So, perhaps I am using the wrong version of Lyxass, which is what I suspected.. Please tell me what your version of Lyxass is, or perhaps post it if that is allowed? Quote Link to comment Share on other sites More sharing options...
+karri Posted January 16, 2008 Share Posted January 16, 2008 include <hardware.asm> What is hardware.asm? I compiled your code with lyxass without problems by removing hardware.asm and hallobm2.spr (as you did not include it). The code is OK in my opinion. -- Karri I don't know what hardware.asm is and it's not *my* code! I'm following the tutorial because, although I am an experienced assembly programmer (with various micros but not 6502) I wanted to learn something about programming for the Lynx. I was hoping I could start with a simple "Hello World" example... I've also tried removing hardware.asm and hallobm2.spr but I still get the syntax errors on the four lines as before. So, perhaps I am using the wrong version of Lyxass, which is what I suspected.. Please tell me what your version of Lyxass is, or perhaps post it if that is allowed? I am not exactly sure which version I am running. On my U3 stick image I have the files included here and they seem to work fine. I copied the files into c:/lynx/bll and it worked for me. -- Karri bll.zip Quote Link to comment Share on other sites More sharing options...
Lynxer Posted January 16, 2008 Author Share Posted January 16, 2008 Hi Karri It works! The lyxass you provided reports the same version but is actually a different file from the lyxass I was using. Many thanks for your help. Quote Link to comment Share on other sites More sharing options...
