Software sprites and 3-d starfield code
Is there any place where people leave sources for assorted routines. Anything from PM graphics to the two things I am especially interested in. I want the fastest, best routine to move a software sprite on a screen with four colors or maybe even graphics 9, 10 or 11. Guess the routines are a little different, but maybe not too much.
Also, a 3-D starfield, like the one in Star Raiders. Anybody have a good routine for that?
Thanks and take Atarian care
it all depends on what you wanna do. Do more precise your idea is the better you can tweak your routine. Generic routines are always costly when it comes to performance.
check this out:
http://sources.pigwa.net/
http://atariwiki.strotmann.de
http://mads.atari8.info/
(MADS includes a lot nice code examples)
cheers
\twh::taos
3-D Star Field is pretty easy. It is just an array of x,y coordinates for each star.
Each star is assigned a random screen position and random brightness (withing limits of the display device's ability to show brightness), and each moves at a random speed across the screen, all in the same direction. With each cycle of the game loop, each star erased and redrawn in a new position based on its speed, and it's coordinates are updated.
When stars get to the edge of the screen, they get wrapped around back to the other side, and the speed and brightness (possibly vertical position) might get assigned new random values.
That's a reasonable approach if you just want something that looks kinda sorta like a star field, though stars that reach the edge should reset to the center of the screen rather than the opposite edge, and you need to control the distribution of velocities to ensure it looks reasonable. If nothing else, require that either |dx| is greater than some minimum, |dy| is greater than some minimum, or |dx|+|dy| is greater than some minimum. If a random choice of speeds doesn't meet those requirements, reject the star. Otherwise you may get some stars that just 'sit' in the middle of the screen or move excessively slowly.
If you want to allow the user to fly around the starfield interactively, things are harder, particularly since starfields as commonly drawn are completely unrealistic. If it takes one second for a star to move from being 1/10 of the way from the center of the screen to 1/5, that means that in that time the player has traversed half the distance to that star. In BattleZone, the mountains are always at distance infinity, but for a starfield to move nicely the player must be so close to the stars as to be able to reach them in seconds.
Here is an ANALOG article, with ACTION! source code, that shows how to do a 3D star field.
http://www.cyberroach.com/analog/an20/stars3d_action.htm
Sorry, I just tested this code. It is not 3D like Star Raiders but is actually pseudo-3D or parallax scrolling.
Edited by joyfulcoder
Thanks for the replies. I think some of the replies is what I would call 2-d starfield, like in a horisontal shooter, but I need 3-D maths for the starfield. I guess the links I got, though polish, can help with some of my concerns, if the source code for Fred, Misja and those are complete. Will read through and see if I can use any.
Alternate Reality intro also has the 3-D starfield, but it doesn't have to be an Atari 8-bit code I guess. If there's C64 coders that have done it, same math should work.
Thanks again and take Atarian care
