kenfused Posted January 22, 2008 Share Posted January 22, 2008 I am trying to get savekey working on the 7800. The problem I am having is even when the SaveKey is not plugged in, it doesn't produce an error when I read from it. Is there any way I can detect if one is plugged in? Is the problem when it is not plugged in the value will still produce the same value as when the code reads back the status bit? Thanks, Ken SWCHA = $280 ;P0, P1 Joystick Directional Input CTLSWA = $281 ;I/O Control for SCHWA I2C_SDA_MASK = $04 I2C_SCL_MASK = $08 .importzp memCardZpTempWord ; only used (temporarily) if MemCardWrite and MemCardRead functions are used .import memCardTemp ; temp used for almost all functions .export MemCardReadPage, MemCardWritePage ;a/x points to buffer ;y is byte count MemCardWritePage: sta memCardZpTempWord stx memCardZpTempWord+1 sty memCardTemp lda #0 lsr memCardTemp ror a lsr memCardTemp ror a pha lda memCardTemp pha jsr i2c_startwrite bcs @error pla jsr i2c_txbyte pla jsr i2c_txbyte ldy #0 @lpmcwr: lda (memCardZpTempWord),y jsr i2c_txbyte iny cpy #64 bne @lpmcwr jsr i2c_stopwrite clc rts @error: pla pla sec rts ;a/x points to buffer ;y is page number (64 byte pages) MemCardReadPage: sta memCardZpTempWord stx memCardZpTempWord+1 sty memCardTemp lda #0 lsr memCardTemp ror a lsr memCardTemp ror a pha lda memCardTemp pha jsr i2c_startwrite bcs @error pla jsr i2c_txbyte pla jsr i2c_txbyte jsr i2c_stopwrite jsr i2c_startread ldy #0 @lpmcrd: jsr i2c_rxbyte sta (memCardZpTempWord),y iny cpy #64 bne @lpmcrd jsr i2c_stopread clc rts @error: pla pla sec rts i2c_start: lda #I2C_SCL_MASK sta SWCHA lda #I2C_SCL_MASK|I2C_SDA_MASK sta CTLSWA rts i2c_stop: lda #$00 sta SWCHA lda #I2C_SCL_MASK|I2C_SDA_MASK sta CTLSWA lda #I2C_SCL_MASK sta SWCHA lda #$00 sta CTLSWA rts ;-------------------------------------------------------------------- ;i2c+txbit - transmit a bit. ; ; parameters: ; carry flag = bit to transmit ; ; returns: ; nothing ; ; notes: ; x and y are preserved ;-------------------------------------------------------------------- i2c_txbit: lda #$00 sta SWCHA lda #$01 rol a ;shift in carry asl a asl a sta CTLSWA ; SDA = !C lda #I2C_SCL_MASK sta SWCHA rts ;-------------------------------------------------------------------- ;i2c+txack - transmit an ack ;i2c+txnak - transmit an nak ; ; parameters: ; none ; ; returns: ; nothing ; ; notes: ; x and y are preserved ;-------------------------------------------------------------------- i2c_txack: lda #$00 sta SWCHA lda #I2C_SCL_MASK|I2C_SDA_MASK bne com1 i2c_txnak: lda #$00 sta SWCHA lda #I2C_SCL_MASK com1: sta CTLSWA lda #I2C_SCL_MASK sta SWCHA rts ;-------------------------------------------------------------------- ;i2c_rxack - receiving an ack ;i2c_rxbit - receive a bit ; ; parameters: ; none ; ; returns: ; bit or ack in carry ; ; notes: ; x and y are preserved ;-------------------------------------------------------------------- i2c_rxack: i2c_rxbit: lda #$00 sta SWCHA lda #I2C_SCL_MASK sta CTLSWA lda #I2C_SCL_MASK sta SWCHA lsr a lsr a lsr a ; C = SDA rts ;-------------------------------------------------------------------- ;i2c_startread - send eeprom start read command ;i2c_startwrite - send eprom start write command ; ; parameters: ; none ; ; returns: ; nothing ; ; notes: ; x and y are preserved ;-------------------------------------------------------------------- i2c_startread: clv jsr i2c_start lda #$A1 ; eeprom read command bne i2c_txbyte ; always i2c_startwrite: jsr i2c_start lda #$A0 ; eeprom write command bne i2c_txbyte ; always ;-------------------------------------------------------------------- ;i2c_txbyte - transmit a byte to the memory card ; ; parameters: ; a - byte to transmit ; ; returns: ; bit with ack ; ; notes: ; y is preserved ;-------------------------------------------------------------------- i2c_txbyte: eor #$ff ; invert data byte sta memCardTemp ldx #$08 ; loop counter @lp: asl memCardTemp ; shift next bit into C jsr i2c_txbit ; transmit dex bne @lp jmp i2c_rxack ;-------------------------------------------------------------------- ;i2c_rxbyte - receive a byte from the memory card ;i2c_rxbyte ; ; parameters: ; none ; ; returns: ; a - byte received ; ; notes: ; y is preserved ;-------------------------------------------------------------------- i2c_rxbyte: ldx #$08 ; loop counter bvc @skack ; previous byte needs acknowledge? jsr i2c_txack ; transmit acknowledge bit @lp: jsr i2c_rxbit ; receive bit in C rol memCardTemp ; rotate into scratchpad dex bne @lp lda memCardTemp ; get received byte from scratchpad rts @skack: bit @blah @blah: bvs @lp i2c_stopread: bvc i2c_stopwrite jsr i2c_txnak ; transmit no-acknowledge i2c_stopwrite: jmp i2c_stop Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted January 22, 2008 Share Posted January 22, 2008 I think this is wrong: i2c_rxack: i2c_rxbit: lda #$00 sta SWCHA lda #I2C_SCL_MASK sta CTLSWA lda #I2C_SCL_MASK sta SWCHA lsr a lsr a lsr a ; C = SDA rts I think you want to load SWCHA and then shift the bit into the carry. Quote Link to comment Share on other sites More sharing options...
kenfused Posted January 23, 2008 Author Share Posted January 23, 2008 I think this is wrong: i2c_rxack: i2c_rxbit: lda #$00 sta SWCHA lda #I2C_SCL_MASK sta CTLSWA lda #I2C_SCL_MASK sta SWCHA lsr a lsr a lsr a ; C = SDA rts I think you want to load SWCHA and then shift the bit into the carry. Many thanks. You don't know how many times I have looked over the code and missed that. --Ken Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted January 23, 2008 Share Posted January 23, 2008 No problem. I've had similar blocks...sometimes you just need another set of eyes. Quote Link to comment Share on other sites More sharing options...
