27ace27 Posted February 1, 2008 Share Posted February 1, 2008 there is this piece that goes in the circled area of the space bar that is missing and i need a new one and what are the black sticky things for? and lastly are those moisture looking dots on the circuit board suppossed to be there? Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 1, 2008 Share Posted February 1, 2008 The metal shield is missing from the cartridge bay door, HAL: The circuit board seems to be bubbling out a bit - fairly natural for really old gear. Quote Link to comment Share on other sites More sharing options...
Tempest Posted February 1, 2008 Share Posted February 1, 2008 The metal shield is missing from the cartridge bay door, HAL: Yep my personal Atari 400 (from 1980) did the same thing. I need to stick it back on sometime. Tempest Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 1, 2008 Author Share Posted February 1, 2008 The metal shield is missing from the cartridge bay door, HAL: The circuit board seems to be bubbling out a bit - fairly natural for really old gear. could I get a new shielding? and do you know if a 5200 power adapter would KILL a 400? Quote Link to comment Share on other sites More sharing options...
+bcombee Posted February 1, 2008 Share Posted February 1, 2008 (edited) According to the Best Electronics catalog, the Atari 400 uses a 9V AC power supply (18.5W for the 400-only supply, 50W for the universal one), where the 5200 uses a dual 9.3V/11.3V DC power supply. In other words, don't plug the 5200 supply into this computer! Edited February 1, 2008 by bcombee Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 1, 2008 Author Share Posted February 1, 2008 According to the Best Electronics catalog, the Atari 400 uses a 9V AC power supply (18.5W for the 400-only supply, 50W for the universal one), where the 5200 uses a dual 9.3V/11.3V DC power supply. In other words, don't plug the 5200 supply into this computer! its sooooooooo tempting Quote Link to comment Share on other sites More sharing options...
mimo Posted February 1, 2008 Share Posted February 1, 2008 B+C have those keyboards if you want a complete replacement, about $25 IIRC Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 2, 2008 Author Share Posted February 2, 2008 B+C have those keyboards if you want a complete replacement, about $25 IIRC where woud you get it? Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted February 2, 2008 Share Posted February 2, 2008 B+C have those keyboards if you want a complete replacement, about $25 IIRC where woud you get it? B&C Computervisions http://www.myatari.com/ Or try Best Electronics http://www.best-electronics-ca.com/ Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted February 2, 2008 Share Posted February 2, 2008 According to the Best Electronics catalog, the Atari 400 uses a 9V AC power supply (18.5W for the 400-only supply, 50W for the universal one), where the 5200 uses a dual 9.3V/11.3V DC power supply. In other words, don't plug the 5200 supply into this computer! well, you could plug it in but it won't work. it shouldn't damage the computer how ever. the ram in the 400 and the 800 need +12V, +5V and -5V to work. all of which is derived from the 9V ac. james Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 4, 2008 Author Share Posted February 4, 2008 According to the Best Electronics catalog, the Atari 400 uses a 9V AC power supply (18.5W for the 400-only supply, 50W for the universal one), where the 5200 uses a dual 9.3V/11.3V DC power supply. In other words, don't plug the 5200 supply into this computer! well, you could plug it in but it won't work. it shouldn't damage the computer how ever. the ram in the 400 and the 800 need +12V, +5V and -5V to work. all of which is derived from the 9V ac. james so it wouldnt kill it? Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 4, 2008 Author Share Posted February 4, 2008 The metal shield is missing from the cartridge bay door, HAL: The circuit board seems to be bubbling out a bit - fairly natural for really old gear. Where would i get a new shielding? Quote Link to comment Share on other sites More sharing options...
andylama Posted February 4, 2008 Share Posted February 4, 2008 As for the "moisture looking" or "bubbling out"--don't worry, that appearance is normal. In most cases, it is an unusually thick layer of solder, flow-coated over the circuit traces during manufacture. Then they apply a protective green coating over that to prevent oxidation. All in all, it's a good thing. Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 5, 2008 Author Share Posted February 5, 2008 The metal shield is missing from the cartridge bay door, HAL: The circuit board seems to be bubbling out a bit - fairly natural for really old gear. Where would i get a new shielding? still no reply... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 10, 2008 Share Posted February 10, 2008 That shield is not necessary. The only way to get another one would be from a donor machine, or you could always cut your own fom a thin sheet of aluminum. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 12, 2008 Author Share Posted February 12, 2008 That shield is not necessary. The only way to get another one would be from a donor machine, or you could always cut your own fom a thin sheet of aluminum. Stephen Anderson so what would bo the specs? how long/wide/thick/ and the angle of the bend so i can get one machened Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 13, 2008 Share Posted February 13, 2008 For that missing spacebar piece, you could probably make your own using that one as a template, just find a piece of plastic of about the same thickness and use and exacto/razor knife to trim it to the same shape, then use a drill to cut the hole (get a proper bit that fits the width, then make two holes spaced for the oval shape then use the razor knife to cut the rest out. Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 13, 2008 Author Share Posted February 13, 2008 For that missing spacebar piece, you could probably make your own using that one as a template, just find a piece of plastic of about the same thickness and use and exacto/razor knife to trim it to the same shape, then use a drill to cut the hole (get a proper bit that fits the width, then make two holes spaced for the oval shape then use the razor knife to cut the rest out. BUT I DONT HAVE ONE RIGHT NOW, THAT IS WHY I ASKED FOR THE SPECS!!! Quote Link to comment Share on other sites More sharing options...
27ace27 Posted February 13, 2008 Author Share Posted February 13, 2008 For that missing spacebar piece, you could probably make your own using that one as a template, just find a piece of plastic of about the same thickness and use and exacto/razor knife to trim it to the same shape, then use a drill to cut the hole (get a proper bit that fits the width, then make two holes spaced for the oval shape then use the razor knife to cut the rest out. BUT I DONT HAVE ONE RIGHT NOW, THAT IS WHY I ASKED FOR THE SPECS!!! oh wait the spacebar... sorry Quote Link to comment Share on other sites More sharing options...
