Battlezone Posted February 5, 2008 Share Posted February 5, 2008 Sometimes if I connect the adaptor first to the 220V and then to the Lynx, the led make a light for a second (before pressing On) It's not happen if I connect the adaptor first to the lynx and then to the 220V. Is it happened to you? Which is the right procedure? The first case could be dangerous for the system? Quote Link to comment Share on other sites More sharing options...
lynxmatt1980 Posted February 6, 2008 Share Posted February 6, 2008 i dont think you're risking any damage as long as the voltage is correct. AC adapters are designed to not spike and fry equipment. With Portable stuff, its usually easier to plug into the wall then connect the plug into the lynx,gameboy, phone, or whatever you are connecting. Quote Link to comment Share on other sites More sharing options...
Battlezone Posted February 7, 2008 Author Share Posted February 7, 2008 Thanks for the answer! I did it many time and the console still works perfectly. Quote Link to comment Share on other sites More sharing options...
