z28in82 Posted August 5, 2002 Share Posted August 5, 2002 Is it possible to run a Genesis II with a Side mounted Sega CD and have the 32X running? when I have tried to set them up for some reason the games won't read. but if I seperated the cd from the Genesis the 32x will work and when i remove the 32x the cd works with no problem. So could I be messing up soemwhere or is this a common problem? Thanks, Z28in82 Quote Link to comment Share on other sites More sharing options...
Lemmi Posted August 5, 2002 Share Posted August 5, 2002 Yes it is possible, you must have something connected wrong or you might be missing a key connection somewhere - because this is my set up as well Genesis 2 sega CD 2 and the 32X but i couldnt tell you for sure as i havent unhooked or hooked up my set up in over 4 years Quote Link to comment Share on other sites More sharing options...
z28in82 Posted August 5, 2002 Author Share Posted August 5, 2002 well thanks, I mean I hardly use the 32x only 2 games for it Star Wars & Doom. So it isn't like I have a brning desire just more of a nagging frusteration Z28in82 Quote Link to comment Share on other sites More sharing options...
Markimus of K. Posted August 5, 2002 Share Posted August 5, 2002 I've got the same setup a lemmi, never had any problems. But I know what you mean, one little thing not working and it drives you nuts! Usually it's best to sleep on it and the next day you go "AHA!" it was only x! But no, if your like me you'll spend most of the night in frustration screaming at the offending piece of equipment. Ok, that didn't help you much, maybe try to give us a detailed description of the cabling setup you're using and we can figure it out. As Always, Markimus of K. Quote Link to comment Share on other sites More sharing options...
z28in82 Posted August 7, 2002 Author Share Posted August 7, 2002 well guys I just wanted to thank you, I dunno what I did differently but this time when i went and set everything up it worked perfectly so I have no idea what cable I had crossed but now all is working so thank you for your help Z28in82 Quote Link to comment Share on other sites More sharing options...
