Primordial Ooze Posted February 15, 2008 Share Posted February 15, 2008 (edited) When i try to compile my game i get the following error: ---------- Capture Output ----------> "C:\Atari2600\bB\2600bas.bat" C:\Projects\Atari\OpenSourcePong\opensourcepong.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left 2643 bytes of ROM space left 2643 bytes of ROM space left --- Unresolved Symbol List mul8 0000 ???? (R ) Fatal assembly error: Source is not resolvable. > Terminated with exit code 0. Code: rem Open Source Pong rem an Open Source Pong Remake rem Updated: Feburary 10, 2008 rem Website: http://opensourcepong.freepgs.com rem set the rom size set romsize 4k rem set kernel options rem readpaddle - set it so the paddle controlers are read set kernel_options no_blank_lines readpaddle rem set an alias for the ball's x velocity dim ballxvelocity = a rem set an alias for the ball's y velocity dim ballyvelocity = b rem set an alias for the player1's score dim player1score = c rem set an alias for the player2's x score dim player2score = d rem set player1's inital x positon player0x = 15 rem set player1's inital y positon player0y = 45 rem set player2's inital x positon player1x = 140 rem set player2's inital y positon player1y = 45 rem set ball's inital x positon ballx = 80 rem set ball's inital y positon bally = 45 rem start of the game loop gameLoop rem color the background black' COLUBK = 0 rem set the color of the playfield to white COLUPF = 14 rem define the playfield playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem color player 1's paddle COLUP0 = 14 rem define player 1's sprite player0: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem color player 2's paddle COLUP1 = 14 rem define player 2's sprite player1: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem read paddle 0, use it to position player0x across the screen currentpaddle = 0 rem draw the game screen drawscreen rem set player1's y position to the paddle control's axis rem multiplied by 2 plus 1 rem player0y = 2 * paddle + 1 rem make sure the player doesn't go off the top screen if player0y > 153 then player0y = 153 rem make sure the player doesn't go off the bottom screen if player0y < 8 then player0y = 8 rem redraw the screen drawscreen goto gameLoop To test it remove the rem from the following statement: player0y = 2 * paddle + 1 Thanks, Open Source Pong Edited February 15, 2008 by Space Xscape Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 15, 2008 Share Posted February 15, 2008 --- Unresolved Symbol Listmul8 0000 ???? (R ) "mul8" is used in the multiplication. If you get an error because it wasn't found (i.e., "unresolved symbol"), then you need to add the following line to your program: include div_mul.asm Michael Quote Link to comment Share on other sites More sharing options...
Robert M Posted February 15, 2008 Share Posted February 15, 2008 Try: paddle * 2 + 1 Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted February 15, 2008 Author Share Posted February 15, 2008 Try: paddle * 2 + 1 That worked thanks Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 15, 2008 Share Posted February 15, 2008 Try: paddle * 2 + 1 That worked thanks In this case it works, because it's "* 2," and multiplication by 2 doesn't require either the div_mul.asm or div_mul16.asm includes. But from a more general standpoint, if you get a compile error that lists "mul8" as an unresolved symbol, then you need to add "include div_mul.asm" to your program. Michael Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted February 15, 2008 Author Share Posted February 15, 2008 Cool, it's good to know this, Thanks. Quote Link to comment Share on other sites More sharing options...
