Atari_Owl Posted August 6, 2002 Share Posted August 6, 2002 Hi guys, umm, another NATIVE question. I recently got the NATIVE demo that came with Protector SE. I'm in the UK and when i tried it out on my PAL Jaguar it flickered all over the place and looked awful. Anyway, i got a cheap NTSC jaguar just the other day, and figuring that perhaps it was only suitable for NTSC tried NATIVE with that. It was just as unusable. I'm sure the NTSC jag is working fine cause the big black border at the bottom of Protectoir vanished, but NATIVE is still wrong. Any ideas guys? Cheers. Quote Link to comment Share on other sites More sharing options...
Tyrant Posted August 6, 2002 Share Posted August 6, 2002 On my pal Jaguar it works fine, I do remember manic flickering on the game over message, but I might be confusing that with Lars' new "Ball Game" (my memory is terrible sometimes). Quote Link to comment Share on other sites More sharing options...
+rdemming Posted August 6, 2002 Share Posted August 6, 2002 Native runs always in 60Hz. Even when you have a PAL Jaguar. Most PAL TVs can't sync on a 60Hz RF signal, thats why the image is flickering. Best is to use a SCART-RGB cable to connect your Jaguar to your TV. Most PAL televisions display a 60Hz RGB signal correctly. And the image quality is much better than RF. Robert Quote Link to comment Share on other sites More sharing options...
Tyrant Posted August 6, 2002 Share Posted August 6, 2002 Ah that'll do it, Im on a sony tv, able to handle almost any kind of signal you can give it, I'd never go back to another brand now I've had sony </advert> Quote Link to comment Share on other sites More sharing options...
Gunstar Posted August 6, 2002 Share Posted August 6, 2002 I downloaded NATIVE with JUGS on two different NTSC Jags, with 4 different tv's hooked up, new and old, and I always had problems with the color on this game. Everything was basically always black&white, with strange rainbow colored "flickering" on bright areas and occasional color "pop-on" for an instant every so often. I was told that it was because the game is PAL, and even my new (with five years) Sharp '36 inch monitor probably wasn't multisync, but I haven't ever tried anything else in PAL on the TV, so I don't know if it is or not. Never bothered to look for the Tv maual either though...I've heard of others having the same problem, but I've also heard of others not having a problem, so wh o knows? Quote Link to comment Share on other sites More sharing options...
Thunderbird Posted August 6, 2002 Share Posted August 6, 2002 I've played several different versions of native on several TV's and through CD loading and loading with BJL, JUGS, and Alpine boards it always has a flickering of the color on a TV with composite or R/F. S-Video is much better. On RGB it's rock solid. I always heard it was in PAL, so I'm not sure what's up. Quote Link to comment Share on other sites More sharing options...
Garvin Posted August 6, 2002 Share Posted August 6, 2002 The reason for this is because they used a non-standard video setup routine. It has been fixed in later versions (from what I've heard) and new version of Native will have it corrected as well. -Garvin Quote Link to comment Share on other sites More sharing options...
Thunderbird Posted August 7, 2002 Share Posted August 7, 2002 The reason for this is because they used a non-standard video setup routine. It has been fixed in later versions (from what I've heard) and new version of Native will have it corrected as well. -Garvin I knew the video setup was a bit wonky, as I had to make special provisions in the BS cart portion of JUGS to insure the switch to their modes would work. I didn't realize they were the reason for the colors though. Quote Link to comment Share on other sites More sharing options...
Atari_Owl Posted August 7, 2002 Author Share Posted August 7, 2002 Thanks Guys I guess i just have to accept it since its the same on my PAL AND NTSC machines, oh well. At least i've finished my BJL cable and stuff and started transferring data. Quote Link to comment Share on other sites More sharing options...
