+Philsan Posted February 18, 2008 Share Posted February 18, 2008 I would like to change this routine http://www.atariarchives.org/c2bag/page103.php so that players are in single line resolution instead of double line resolution. Can someone help me? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 19, 2008 Share Posted February 19, 2008 559 is the key... change 350 POKE 559,46:POKE 53277,3 into 350 poke 559,62:poke 53277,3 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 19, 2008 Author Share Posted February 19, 2008 I already know that I have to add 16 to have single line resolution. The problem is that other things must be changed in the listing, in particular in lines 200-330. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 19, 2008 Share Posted February 19, 2008 For single-line, the base has to be on a 2K boundary, not 1K. You'll also need to change offsets and counters of 128 to 256. There's also calculations in there with 512, they need to be changed to 1024. 200 A=4*(INT(PEEK(742)/4)-1) That line establishes PMBASE on the 1K boundary below the top of free RAM. So just change the 4s to 8s to align on 2K instead of 1K. Change the -1 to -2 to reserve 2K. Probably more, but you should be able to work it out. That's a kinda dirty way of doing PMGs in BASIC anyway. It's usually better to just move the screen lower in RAM and use the very top of RAM for PMGs - that way they're well protected from the OS or BASIC just overwriting them. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 20, 2008 Author Share Posted February 20, 2008 Thanks for your attention, in particular to Rybags. He changed for me Compute's P/M routine to single line resolution and improved it to protect memory. Perhaps this routine (it runs in Atari Basic and Turbo-Basic XL) can be useful for newbies. 5 REM PMSAMPLE1-SINGLE LINE RESOL. 10 DIM PM1$(256),PM2$(256),PM3$(256) 12 MEMTOP=PEEK(740) 14 POKE 106,MEMTOP-16 16 GRAPHICS 15+16 20 SIZE1=16:SIZE2=8 30 DIM SHIP$(SIZE1),ALIEN$(SIZE2) 40 DIM CLEAR$(256) 50 FOR ROWS=1 TO SIZE1 60 READ DOTS 70 SHIP$(ROWS,ROWS)=CHR$(DOTS) 80 NEXT ROWS 90 DATA 0,0,0,0,0 100 DATA 16,56,56,124,108,68 110 DATA 0,0,0,0,0 120 FOR ROWS=1 TO SIZE2 130 READ DOTS 140 ALIEN$(ROWS,ROWS)=CHR$(DOTS) 145 POKE 53248,X0 150 NEXT ROWS 160 DATA 60,126,219,126,36,36,66,129 170 FOR ROWS=1 TO 256 180 CLEAR$(ROWS,ROWS)=CHR$(0) 190 NEXT ROWS 200 A=MEMTOP-8 210 POKE 54279,A 220 VSA=256*PEEK(135)+PEEK(134) 230 BOA=256*PEEK(141)+PEEK(140) 240 PM=256*A+1024 250 DISP=PM-BOA 260 ADD=2 270 FOR T=1 TO 3 280 PMHIGH=INT(DISP/256) 290 PMLOW=DISP-256*PMHIGH 300 POKE VSA+ADD,PMLOW 310 POKE VSA+ADD+1,PMHIGH 320 DISP=DISP+256:ADD=ADD+8 330 NEXT T 340 PM1$=CLEAR$:PM2$=CLEAR$:PM3$=CLEAR$ 350 POKE 559,62:POKE 53277,3 360 COLR1=25:COLR2=11:COLR3=74 370 POKE 704,COLR1:POKE 705,COLR2:POKE 706,COLR3 380 X1=125:X2=75:X3=175 390 POKE 53248,X1:POKE 53249,X2:POKE 53250,X3 400 Y1=95:Y2=65:Y3=65 410 PM1$(Y1)=SHIP$:PM2$(Y2)=ALIEN$:PM3$(Y3)=ALIEN$ 420 IF STICK(0)<8 THEN X1=X1+3 430 IF STICK(0)>8 AND STICK(0)<13 THEN X1=X1-3 440 IF STICK(0)=14 THEN Y1=Y1-3 450 IF STICK(0)=13 THEN Y1=Y1+3 460 POKE 53248,X1:PM1$(Y1)=SHIP$ 470 IF STICK(1)<8 THEN X2=X2+2 480 IF STICK(1)>8 AND STICK(1)<13 THEN X2=X2-2 490 POKE 53249,X2 500 IF STICK(2)<8 THEN X3=X3+2 510 IF STICK(2)>8 AND STICK(2)<13 THEN X3=X3-2 520 POKE 53250,X3 530 GOTO 420 P107L1SL.zip Quote Link to comment Share on other sites More sharing options...
