Potemkyn Posted February 25, 2008 Share Posted February 25, 2008 Howdy; I am in need of a disk editor. One that will allow me to change specific characters on the disk. I used to have a copy of SPARTA DOS that had such an editor, but no more. Can you recommend any other programs? Also, I have a cable to hook up my PC to my 1050 drive, but something no longer works. It's a simple cable with a serial port on one end and the SIO port on the other. We used this years ago to read and store a few atari disk images to the PC. Perhaps I am not remembering how to use the program properly (I've tired it using two different PCs and two different 1050s). What program do you recommend to read and write to you Atari drive from your PC - or Apple? thanks Mike ~Po Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 25, 2008 Share Posted February 25, 2008 Howdy; I am in need of a disk editor. One that will allow me to change specific characters on the disk. I used to have a copy of SPARTA DOS that had such an editor, but no more. Can you recommend any other programs? Also, I have a cable to hook up my PC to my 1050 drive, but something no longer works. It's a simple cable with a serial port on one end and the SIO port on the other. We used this years ago to read and store a few atari disk images to the PC. Perhaps I am not remembering how to use the program properly (I've tired it using two different PCs and two different 1050s). What program do you recommend to read and write to you Atari drive from your PC - or Apple? thanks Mike ~Po One way to do it is via MPDOS Pro available at http://www.krishnasoft.com/SPS.htm. It comes with utility to extract or write files to image disks or to use them directly and you can use the DEBUG on the PC end to modify the hex or ASCII stuff. Let me know if you are interested in this method... I haven't been auctioning much recently since ebay started eating up around 20% of the sales. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted February 25, 2008 Share Posted February 25, 2008 (edited) One way to do it is via MPDOS Pro available at http://www.krishnasoft.com/SPS.htm. It comes with utility to extract or write files to image disks or to use them directly and you can use the DEBUG on the PC end to modify the hex or ASCII stuff. Let me know if you are interested in this method... I haven't been auctioning much recently since ebay started eating up around 20% of the sales. The link above is 4o4! Edit: actually this does work: www.krishnasoft.com Edited February 25, 2008 by bf2k+ Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 26, 2008 Share Posted February 26, 2008 One way to do it is via MPDOS Pro available at http://www.krishnasoft.com/SPS.htm. It comes with utility to extract or write files to image disks or to use them directly and you can use the DEBUG on the PC end to modify the hex or ASCII stuff. Let me know if you are interested in this method... I haven't been auctioning much recently since ebay started eating up around 20% of the sales. The link above is 4o4! Edit: actually this does work: www.krishnasoft.com Thanks for pointing that out. I just listed the MPDOS/cable for Atari 400/800/XL/XE on ebay in-case anyone is interested: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=320222139873 Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted February 27, 2008 Share Posted February 27, 2008 If you already have the 1050-2-PC cable or the SIO-2-PC cable, then you are pretty much ready to go... oops you said it didn't work, well buy a new one from Atarimax as well! Get something like APE (http://www.atarimax.com/) and then download a disk editor (Disk Wiz II should work for you.) Either turn your disk into an ATR first, and then edit it, or just hook up your Atari disk drive as well and edit the disk directly. Quote Link to comment Share on other sites More sharing options...
Potemkyn Posted March 5, 2008 Author Share Posted March 5, 2008 Thanks, y'all. I'll give it a try soon Mike Quote Link to comment Share on other sites More sharing options...
