ClausB Posted February 15 Author Share Posted February 15 (edited) https://archive.org/details/LNBUG2 Interesting Colleen prototype memory maps on pages 16 and 20. CTIA, ANTIC, POKEY, PIA addresses line up with those in this thread's first post. Edited February 15 by ClausB 2 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 15 Author Share Posted February 15 3 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 15 Share Posted February 15 Maybe this helps with the developers side card that Curt had, the left side expansion board of the 800 not in home user machines. Using the map you now know where to attach and how to access some of the ports. Some clue about the switches too. This makes sense especially with the optional second terminal uart for use with the s-100 attached, nice clausb 2 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 15 Author Share Posted February 15 I'm not sure whether or not this Colleen Development System was itself an S-100 machine. Anyone know? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 15 Share Posted February 15 (edited) The machine connected to an s100 through the terminal uart, The s100 was used to perform operations for the unit, They could be operated stand alone or together, not unlike devices today In as much as an s100 back plane was used for development cards, it's not unexpected in development check the notes for stand alone modes there were two uarts for connections with one for PDP and one for s100, mapped in at different locations Edited February 15 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 16 Author Share Posted February 16 Well, MAP-1 above refers to an 8K Byte Saver board, which was S-100: https://en.m.wikipedia.org/wiki/Cromemco_Bytesaver Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 16 Share Posted February 16 (edited) Yes, and there was an m-card (aka m-drive/h) as well as a rom simulator in the s-100 The rom simulator ribbon cable headers plugged into the rom socket There should be three sections of the notes, one for each The mode was either 16k or 8k split so 16k or 8 k and 8k byte saver so that tracks on the s-100 side By split I mean you could program and save 8k and read 8k , as it programmed and read eproms, in almost the same way as ram. So program and read only, or read and write. It's not perfectly clear but more should turn up, kind of nice how things are going in terms of software and hardware being re discovered and unearthed. Edited February 16 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 16 Share Posted February 16 (edited) Maybe this will make more sense... s100 with 2 custom atari cards, one a 6500 series cpu card the other an interface card, 16kbase ram, 32k optional in either two 16k cards , or one 32k card, prom card, byte saver card is optional, but is more convenient, optional rom simulator card, floppy/hard drive card, serial card configured for terminals (remember s100 uses dumb terminals for input and display) this is interfaced to a display and an 800 as well this is not unlike the system used for 2600 software developers My system had an M-Drive/H card for Ram drive or ramdisk etc but that slot is now empty and I can not find the card, I could however use an eprom card in it's place Edited February 16 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 16 Author Share Posted February 16 (edited) From Goldberg & Vendel, 'Business Is Fun': Edited February 16 by ClausB 4 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 16 Share Posted February 16 (edited) That's pretty consistent. Looks about the same as what I have said except mine serves my Atari 800 as a development platform. The system is a mix of compupro, godbout, and other cards. As to name brand, The cromenco, compupro etc they're all s100 machines, consider that they're not unlike clones were over the years. Each step adding on the one before until the hardware engineers and developers platform becomes a software development platform. You find parts of it's suite are not unlike mac65, so which came first? Much appeared to be happening at the same time. Parallel projects on multiple platforms is also common. further edit, just grabbed a manual from archive.org minimum system listed as follows on the s100 1 Atari GVA- 2503 CPU card 1 Dynabyte l6K RAM card 1 Cromemco l6K ROM card 1 Atari GVA-2504 Trace Memory Interface Card You are still going to want a terminal and other odds and ends Edited February 16 by _The Doctor__ 3 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 16 Author Share Posted February 16 6 hours ago, _The Doctor__ said: mine serves my Atari 800 as a development platform. The system is a mix of compupro, godbout, and other cards. Got pics? What CPU? What drives? What OS? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 16 Share Posted February 16 (edited) If it's still alive I could maybe do a quick video of it acting as a keyboard for my 800 and then use the 800 to load some software etc. It's all kind of standard fare for today. 8 inch floppies, hard drive, a bunch of ribbon cable and what not out the back Two for the prom/rom simulator with headers and the serial cables to the dumb terminal etc. I might have to open it up to make sure nothing is nested inside or eaten wires, but it was working a 7 or more years ago. It weighs to much for me to move these days. each part of the the machine is about the size of decent luggage and weighs quite a few pounds. I'm still deciding what to do with it, it also was used to work on apple and ti, The desk was two desks long with apple ii, ti (and expansion), atari 2600, and the three main s100 boxes, followed by two 800's and an XL, the s100 is no longer connected to a network as it no longer exists and certainly not at this location. Edited February 16 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
