MausGames Posted March 22, 2008 Share Posted March 22, 2008 (edited) wrong forum... Edited March 22, 2008 by MausGames Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 22, 2008 Share Posted March 22, 2008 Is it possible to use multiple sprite definitions with the 6lives HUD? I would like to use it as a timer, ammo counter, and power meter all in the same game, with a different graphic for each. I don't mean multiple graphics at the same time, but that would be extremely awesome. I mean different sprite definitions that can be switched between in different parts of a game. The bB online help manual says: "When you assign a number of lives, you ALWAYS need to define (or redefine) the life icon using lives: or the icon won't display correctly." That means you can change the life icon at any time by setting the number of lives and (re)defining the life icon. Note that you can set the number of lives to a variable: rem * test lives include 6lives.asm dim frames = a dim hearts = b dim flasks = c frames = 0 hearts = 5 * 32 flasks = 3 * 32 first lifecolor = $44 lives = hearts lives: %00010000 %00111000 %01111100 %11111110 %11111110 %11111110 %11111110 %01101100 end loop1 drawscreen a = a + 1 if a <> 0 then loop1 second lifecolor = $94 lives = flasks lives: %01111100 %11111110 %11111110 %01111100 %00111000 %00111000 %00111000 %01111100 end loop2 drawscreen a = a + 1 if a <> 0 then loop2 goto first Michael Quote Link to comment Share on other sites More sharing options...
