jcfox Posted April 5, 2008 Share Posted April 5, 2008 (edited) I have a question concerning flicker. I am attempting to increase the amount of cycles for calculation I have by painting the player sprite and the playfield at regular intervals. The code that does this looks like this: (I'm currently drawing the playfield for 2 frames, then the sprite for 2 frames). lda $f4 ; load flip location ($f4 is inc'd at the end of every frame) and #2 ; is it every 2nd frame? beq PictureSprite PicturePlayField The code to draw the Sprite and playfield are pretty basic, the concepts coming mostly from Andrew Davie's tutorial. I can post more if its needed, but my basic question is this: Is it possible to do this without flicker? (for example, does the 2600 allow double buffering somehow)? Thanks, Jason Fox Edited April 5, 2008 by jcfox Quote Link to comment Share on other sites More sharing options...
jcfox Posted April 5, 2008 Author Share Posted April 5, 2008 Well, I did a little more digging through the forums and found that if I set use phosphor to true in stella and set it to every other frame, it looks great. Does any one know if this is how it would look on a real machine? Or, by doing this, am I in 'emulator only' territory? Quote Link to comment Share on other sites More sharing options...
supercat Posted April 5, 2008 Share Posted April 5, 2008 Well, I did a little more digging through the forums and found that if I set use phosphor to true in stella and set it to every other frame, it looks great. Does any one know if this is how it would look on a real machine? Or, by doing this, am I in 'emulator only' territory? The only way to really find out is to try it on real hardware. On some games, 30Hz flicker is barely noticeable. On other games, it's a major eyesore. A few general observations: -1- Large areas that flicker in unison are generally bad. Sometimes very bad, even at 30Hz. -2- Small flickering objects against a black background are not so bad as against a colored background. Dark objects flickering against a light background are generally the worst. -3- In some rare cases, it may be possible to flicker alternate scan lines (showing 'even' scan lines one frame; 'odd' scan lines the next. When that's practical (mainly in things like text kernels), it will often help a lot. -4- Sometimes it's necessary to flicker objects between two colors. This is generally not too noticeable, even with large objects, if both colors have similar luminance. Quote Link to comment Share on other sites More sharing options...
jcfox Posted April 5, 2008 Author Share Posted April 5, 2008 thanks for the advice Quote Link to comment Share on other sites More sharing options...
