311fan Posted April 12, 2008 Share Posted April 12, 2008 I have two systems. Replaced the belt individually on each one. But both give me error 21 or 22 when i try to read a disk. Can anyone tell me if it is the disk or if i need to continue to tweak the motor speed or head alignment? Help! Thanks Quote Link to comment Share on other sites More sharing options...
y-bot Posted April 12, 2008 Share Posted April 12, 2008 I have two systems. Replaced the belt individually on each one. But both give me error 21 or 22 when i try to read a disk. Can anyone tell me if it is the disk or if i need to continue to tweak the motor speed or head alignment? Help! Thanks Hi! Did you follow these directions exactly? http://www.jfgoods.net/disksystem.html The part about lining up the head is really important. y-bot Quote Link to comment Share on other sites More sharing options...
311fan Posted April 12, 2008 Author Share Posted April 12, 2008 Hi! Did you follow these directions exactly? http://www.jfgoods.net/disksystem.html The part about lining up the head is really important. y-bot i tried to align the head as it said but didn't have a wrench small enough to loosen and re-tighten the screw. I guess i'll try that if i can find a wrench small enough. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
y-bot Posted April 15, 2008 Share Posted April 15, 2008 Yeah, I don't understand exactly how lining the head up works but if you don't do it exactly like those instructions show it won't work. I used to think you had to spend hours adjusting the motor but that's not it. I've fixed every one I've worked on (about 5) since I found those instructions. y-bot Quote Link to comment Share on other sites More sharing options...
