Heaven/TQA Posted April 15, 2008 Share Posted April 15, 2008 (edited) I stumped over our Taquart disc mag "Energy zine #1" which uses custom SIO loader... but interesting that it uses 2 sound channels (ok...nothing special...) combined with digi-beat while loading from disc... the issue here is that the sources and tools are available since 1995 but how many productions (demos/games) use such a loader? i do not know another... in other scene people are pushing each other to next level and (re)use techniques... but in Atari scene some some are left over... check it out: http://ftp.pigwa.net/stuff/mirror/ftp.taqu...gy/energy1a.dcm you can boot the .DCM in Atari800win... btw... it's just side 1 of 4...but should give you an idea... on Jaskier's side you find the source code for the sid-loader if you are interested... http://jaskier.atari8.info/# ps. press 1-9 in the main menu to hear some of the best pokey tunes made in MPT... i guess i can recongnise which are made by Xray... Edited April 15, 2008 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 15, 2008 Share Posted April 15, 2008 Checked it on the emulator - it's kinda hard to get an idea of when stuff's loading (even with the visual indicators). Not many games used sound during loads - Alternate Reality/Dungeon, 7 Cities of Gold, and some of the Lucasfilm games are few which come to mind. I'm thinking of doing a project with a custom SIO loader, just to explore the possibilities. I don't know if it's been done, but with the standard I/O rate, you should be able to play 2-bit sound samples in realtime while they load, and not get underrun problems. Of course, the other (more exciting) prospect is that with a more efficient SIO, to be able to have lots of onscreen DLI action for better loading screens. Quote Link to comment Share on other sites More sharing options...
analmux Posted April 15, 2008 Share Posted April 15, 2008 hmmm, sounds interesting. I took a look, but it looks like there are even TWO digi-voices running simultaneously while loading. I still need to find out how a loader can play music (& eventually some gfx effects) Reminds me of "total daze" loader (from TIGHT). This is though not loader with digi-tune, but it is using 3 voices. I still wonder how to reproduce such an effect. You say there's a source. Where can I find it? Quote Link to comment Share on other sites More sharing options...
tebe Posted April 15, 2008 Share Posted April 15, 2008 (edited) I'm thinking of doing a project with a custom SIO loader, just to explore the possibilities. congratulations, you win irq_sio_loader.zip Edited April 15, 2008 by tebe Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 15, 2008 Author Share Posted April 15, 2008 Analogue... just look at "other" projects and in the MPT folder... there is the sources... Rybags... I had the loader on real 5,25 in 1997... so it definitly works... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 15, 2008 Author Share Posted April 15, 2008 (edited) Tebe... thanks! as usual... a lot of comments... but beware...the SIO-loader is only the "preloader" for the intro... the 2nd "SIO-loader" combines the digidrum mpt player MPT24SPP source... Edited April 15, 2008 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 15, 2008 Author Share Posted April 15, 2008 Hard's Joyride, Overmind by Slight and Tight's Total Daze are the only demos i can remember having msx and or gfx effects while loading... Games Eidolon... Seven Cities of Gold (streaming the map) but does AR really have msx while loading??? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 15, 2008 Share Posted April 15, 2008 Pretty sure both AR's do - been years since I've played it on the real machine. Another thought - read the SIO input bit directly, although the timing headaches would probably outweigh the benefits of gaining a voice or two. And you have to "output" even when you're doing input. Quote Link to comment Share on other sites More sharing options...
emkay Posted April 15, 2008 Share Posted April 15, 2008 (edited) The funny thing.... Almost all A8 Games could take usage of some "background" digitized music , while playing a game. What do you guys think, how much cpu (percentage) a game like "Warhawk" actually uses? Possibly 20-30%. How much does it use of the A8's memory? Possibly 20-30% as almost 90% of the A8 games do... This results in 70% in CPU and memory for a player routine in the background... playing some instruments... And together with Hardsynth programming you would have a "new" machine then... I bet... the PAL version of Rescue on Fractalus also could have used digi sounds without getting slower. Edited April 15, 2008 by emkay Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 16, 2008 Author Share Posted April 16, 2008 Emkay... you are really bet that Fractalus has free CPU time??? come on... Carpenter & Co. squeezed out everything they could. What I could imagine would be using the OS-RAM for samples f.e. when Alien is hitting the door or screams when hitting the front window. but not while flying... Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 16, 2008 Share Posted April 16, 2008 My theory on RoF would be that it probably works like modern FPS games, ie - do the game mechanics and physics in real-time. Then, the rendering engine works seperately, displaying new frames at whatever rate it happens to be capable of, given the amount of scenery and objects to be displayed. You can easily tell such games as the movement takes place in big graduated steps when things get busy, but is quick and along smaller steps when the rendering is easy. Quote Link to comment Share on other sites More sharing options...
emkay Posted April 16, 2008 Share Posted April 16, 2008 Emkay... you are really bet that Fractalus has free CPU time??? come on... Carpenter & Co. squeezed out everything they could. What I could imagine would be using the OS-RAM for samples f.e. when Alien is hitting the door or screams when hitting the front window. but not while flying... Heaven. You might have forgotten 2 facts: 1) the PAL version is slower due to the lower refresh speed 2) on PAL machines you have more cycles per frame available Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted April 16, 2008 Share Posted April 16, 2008 Hard's Joyride, Overmind by Slight and Tight's Total Daze are the only demos i can remember having msx and or gfx effects while loading... Games Eidolon... Seven Cities of Gold (streaming the map) but does AR really have msx while loading??? It comes even better... It's not even that "Eidolon" plays music while loading. It rather "loads while playing music". The funny part is that the Lucasarts loader is completely interrupt driven. You fire it off, and it does the complete disk I/O in background. So long, Thomas Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 16, 2008 Author Share Posted April 16, 2008 sure... but again... I doubt that they waste cycles in a CPU heavy engine.... not the Lucasfilm guys. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 16, 2008 Author Share Posted April 16, 2008 but one thing still not discussed... while in C64 scene a lot of games & demos have custom track loaders and on Atari not... Quote Link to comment Share on other sites More sharing options...
twh/f2 Posted April 16, 2008 Share Posted April 16, 2008 but one thing still not discussed... while in C64 scene a lot of games & demos have custom track loaders and on Atari not... this was maybe because the standard c64-1541 os i/o was so unacceptable slow that it was more obvious (auf der hand) to write custom code. grtx, \twh Quote Link to comment Share on other sites More sharing options...
emkay Posted April 16, 2008 Share Posted April 16, 2008 sure... but again... I doubt that they waste cycles in a CPU heavy engine.... not the Lucasfilm guys. They wasted time by doing screen synchronisation. Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 16, 2008 Share Posted April 16, 2008 With the C-64, it became par for the course for software producers to have custom tape and disk I/O. I think I even have the Novaload tape mastering system here somewhere on floppy. Also, the C-64 has the "advantage" that the sound hardware isn't involved in disk/tape I/O, so you're free to do what you want with it. Finally, the C-64 (as I saw it) was the first system where groups/crackers bothered to do fancy intros and/or loading screens, where with the Atari stuff it was either nothing or just some brief text. Quote Link to comment Share on other sites More sharing options...
dwhyte Posted April 16, 2008 Share Posted April 16, 2008 I'm thinking of doing a project with a custom SIO loader, just to explore the possibilities. congratulations, you win Thank you kind sir... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 17, 2008 Author Share Posted April 17, 2008 can someone help me understand the following source and to rewrite the sio-loader plus digi drums? i get interested in this miracle... as i am now into c64 coding there are IRQs all the time... so I want to solve this last Atari thing Rybags and me? *--------* * Player * *--------* opt 5+32 org $a00 bufor equ $980 *--- strona 0 addr equ $00 ,$01 word equ $02 ,$03 audzer equ $04 ,$05 ,$06 ,$07 licslp equ $08 ,$09 ,$0a ,$0b lensmp equ $0c lsbmsb equ $0d adrs1 equ $0e ,$0f adrs2 equ $10 ,$11 adrsmp equ $12 ,$13 typ equ $14 dcb equ $14 ,$15 ,$16 ,$17 cksum equ $18 xdone equ $19 lindex equ $1a stcnt equ $1b adr equ $1c ,$1d end equ $1e ,$1f wsk equ $20 gdzie equ $21 *--- program jmp init play lda czygrc bne *+3 rts lda #0 sta oraaud inc licz lda pozptr cmp maxptr bcc r1 dec zegar beq p1 jmp r5 p1 ldx #0 stx pozptr p2 lda #0 sta ptrwsk,x sta licspc,x lda adrtrl,x sta addr lda adrtrh,x sta addr+1 ldy pozsng p3 lda (addr),y iny cmp #$ff beq p5 cmp #$fe bne p6 p4 jmp inic2 p5 lda (addr),y bmi p4 asl @ tay sty pozsng jmp p3 p6 sta numptr,x lda (addr),y sta poddzw,x p7 inx cpx #4 bne p2 iny sty pozsng jmp r5 r1 dec zegar bpl r5 lda tempo sta zegar ldx #3 r2 dec licspc,x bpl r4 lda numptr,x asl @ tay aptrlz lda $ffff,y sta addr iny aptrhz lda $ffff,y sta addr+1 ora addr beq r4 lda ptrwsk,x sta licptr jsr newdzw ldy licptr iny tya sta ptrwsk,x lda ilespc,x sta licspc,x cpx #2 bne r4 lda adcvol,x eor #$f asl @ asl @ asl @ asl @ adc <volstb sta volsmp+1 lda >volstb adc #0 sta volsmp+2 r4 dex bpl r2 inc pozptr r5 ldx #1 lda typsmp cmp #2 beq r6 ldx #3 r6 lda typsmp cmp #2 bne r7 cpx kansmp beq r8 r7 jmp dzwiek r8 lda audzer,x and filtry,x beq r9 ldy #$28 lda (addr),y clc adc numdzw,x jsr czest sec adc p1pom,x sta freq+2,x r9 dex bpl r6 jump jmp *+3 lda #3 sta $d20f lda audzer+1 and #$10 beq w1 ldy numdzw+1 lda bsfrql,y sta freq lda bsfrqh,y sta freq+1 w1 lda freq sta $d200 lda freq+1 sta $d202 lda freq+2 sta $d204 lda freq+3 sta $d206 lda volume ldx #$ff ldy typsmp cpy #1 bne w2 ldx kansmp beq w3 w2 sta $d201 w3 lda volume+1 cpx #1 beq w4 sta $d203 w4 cpy #2 beq w6 lda volume+2 cpx #2 beq w5 sta $d205 w5 lda volume+3 cpx #3 beq w6 sta $d207 w6 lda audzer ora audzer+1 ora audzer+2 ora audzer+3 ora oraaud sta $d208 rts filtry dta b(4),b(2),b(0),b(0) jamp lda freq sta $d200 lda freq+1 sta $d202 lda volume sta $d201 lda volume+1 sta $d203 ldx #1 cpx $d40b bcs *-3 rts dzwiek lda adrinl,x sta addr lda adrinh,x sta addr+1 ora addr bne d0 sta volume,x sta audzer,x jmp r9 d0 ldy licslp,x cpy #$20 beq d3 lda (addr),y sec sbc adcvol,x bit sprvol beq d1 and #$f0 d1 sta volume,x iny lda (addr),y sta przech iny sty licslp,x and #7 beq d4 tay lda akcadl-1,y sta akjmpz+1 lda akcadh-1,y sta akjmpz+2 lda przech lsr @ lsr @ lsr @ lsr @ lsr @ ora #$28 tay lda (addr),y clc akjmpz jsr $ffff d2 lda #0 sta audzer,x jmp r9 d3 lda p3max,x beq d4 dec p3lic,x bne d4 sta p3lic,x lda volume,x and #15 beq d4 dec volume,x d4 ldy #$23 lda (addr),y sta audzer,x lda trnlic,x clc adc #$25 tay and #3 sta trnlic,x dey lda (addr),y adc adcdzw,x sta numdzw,x jsr czest+2 sta freq,x lda p2lic,x beq d5 dec p2lic,x jmp r8 d5 lda branch,x sta p1jmpz+1 p1jmpz bpl * jmp typ0dz brk jmp typ1dz brk jmp typ2dz brk jmp typ3dz czygrc dta b(0) jmp typ4dz zapisx dta b(0) jmp typ5dz zapisy dta b(0) jmp typ6dz sprvol dta b($10) jmp typ7dz newdzw lda #0 sta adcvol,x ldy licptr dey new iny lda (addr),y cmp #$fe bne q0 sty licptr rts q0 cmp #$e0 bcc q1 lda maxptr sta pozptr bne new q1 cmp #$d0 bcc q2 and #15 sta tempo sta zegar bpl new q2 cmp #$c0 bcc q3 and #15 eor #15 sta adcvol,x bpl new q3 cmp #$80 bcc q4 and #$3f sta ilespc,x bpl new q4 cmp #$40 bcc q5 iny sty licptr and #$1f sta numsmp,x asl @ tay ainslz lda $ffff,y sta adrinl,x iny ainshz lda $ffff,y sta adrinh,x jmp newdzw q5 sty licptr sta przech clc adc poddzw,x sta adcdzw,x lda typsmp beq n9 cmp #2 beq n8 lda numsmp,x cmp #$1f bne n9 lda przech sec sbc #1 n6 and #15 tay lda (adrsmp),y sta adrs2+1 tya ora #$10 tay lda (adrsmp),y sta lensmp ldy #1 ora adrs2+1 bne n7 ldy #0 n7 sty czysmp lda #0 sta adrs2 sta adrinl,x sta adrinh,x txa asl @ sta wsksmp stx kansmp rts n8 cpx #2 bcs nb n9 lda adrinl,x sta word lda adrinh,x sta word+1 ora word beq na-1 ldy #$20 lda (word),y and #15 sta p1lsb,x lda (word),y and #$70 lsr @ lsr @ sta branch,x iny lda (word),y asl @ asl @ pha and #$3f sta p2lic,x pla and #$c0 sta frqwsk,x iny lda (word),y sta p3max,x sta p3lic,x lda #0 sta licslp,x sta trnlic,x sta p1lic,x sta p1pom,x lda adcdzw,x sta numdzw,x jsr czest sta freq,x cpx kansmp beq na rts na ldy #$ff sty kansmp iny sty czysmp rts nb cpx #2 bne nd ldy adcdzw+2 lda frsmpl,y sta smpl1z+1 lda frsmph,y sta smpl2z+1 lda #0 sta lsbmsb sta adrs1 lda numsmp+2 and #15 tay lda (adrsmp),y sta adrs1+1 tya ora #$10 tay lda (adrsmp),y sta smpl3z+1 ora adrs1+1 bne nc sta smpl1z+1 sta smpl2z+1 nc rts nd lda numsmp+3 and #15 tay lda (adrsmp),y sta adrs2+1 tya ora #$10 tay lda (adrsmp),y ora adrs2+1 beq ne lda (adrsmp),y sec sbc adrs2+1 sta lensmp lda #0 sta adrs2 lda #$8d bne nf ne lda #$ad nf sta drum1z sta drum2z sta drum3z sta drum4z lda #$18 sta $d207 rts typ0dz lda licz and #7 lsr @ lsr @ bcc t2 bne typ1dz lda p1lsb,x t1 clc sta p1pom,x adc freq,x sta freq,x jmp r8 t2 lda #0 sta p1pom,x jmp r8 typ1dz lda freq,x sec sbc p1lsb,x sta freq,x sec lda #0 sbc p1lsb,x sta p1pom,x jmp r8 typ2dz lda p1lic,x clc sta p1pom,x adc freq,x t3 sta freq,x clc lda p1lic,x adc p1lsb,x sta p1lic,x jmp r8 typ3dz lda numdzw,x sec sbc p1lic,x t4 sta numdzw,x jsr czest jmp t3 typ4dz lda #0 sec sbc p1lic,x sta p1pom,x lda freq,x sec sbc p1lic,x jmp t3 typ5dz lda numdzw,x clc adc p1lic,x jmp t4 typ6dz jsr t5 jmp t1 typ7dz jsr t5 clc adc numdzw,x jsr a3 jmp r8 t5 ldy p1lic,x lda p1lsb,x bmi t6 iny iny t6 dey tya sta p1lic,x cmp p1lsb,x bne t7 lda p1lsb,x eor #$ff sta p1lsb,x t7 lda p1lic,x rts czest and #$3f ora frqwsk,x tay t1frqz lda $ffff,y rts akcadl dta l(a1),l(a0),l(a2) dta l(a4),l(a5),l(a6),l(a8) akcadh dta h(a1),h(a0),h(a2) dta h(a4),h(a5),h(a6),h(a8) audora dta b($40),b(0),b($20),b(0) a0 adc freq,x a1 sta freq,x rts a2 adc adcdzw,x a3 sta numdzw,x jsr czest sta freq,x rts a4 sta freq,x lda audora,x bpl a7 a5 sta freq,x lda #$80 bne a7 a6 sta freq,x lda #1 a7 ora oraaud sta oraaud rts a8 and $d20a sta freq,x a9 rts bsfrql equ *-1 dta b($f2),b($33),b($96) dta b($e2),b($38),b($8c),b(0) dta b($6a),b($e8),b($6a),b($ef) dta b($80),b(,b($ae),b($46) dta b($e6),b($95),b($41),b($f6) dta b($b0),b($6e),b($30),b($f6) dta b($bb),b($84),b($52),b($22) dta b($f4),b($c8),b($a0),b($7a) dta b($55),b($34),b($14),b($f5) dta b($d8),b($bd),b($a4),b($8d) dta b($77),b($60),b($4e),b($38) dta b($27),b($15),b(6),b($f7) dta b($e8),b($db),b($cf),b($c3) dta b($b8),b($ac),b($a2),b($9a) dta b($90),b($88),b($7f),b($78) dta b($70),b($6a),b($64),b($5e) bsfrqh equ *-1 dta $0d,$0d,$0c,$0b,$0b,$0a,$0a,$09,$08,$08,$07,$07,$07,$06,$06 dta $05,$05,$05,$04,$04,$04,$04,$03,$03,$03,$03,$03,$02,$02,$02,$02 dta $02,$02,$02,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$00 dta $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 volstb dta d'8888888888888888' dta d'667777888889999:' dta d'556667788899:::;' dta d'455667788899::;;' dta d'44556677899::;;<' dta d'34456677899::;<<' dta d'33455677899:;;<=' dta d'23445677899:;<<=' dta d'2334566789::;<==' dta d'2234566789::;<=>' dta d'1234566789::;<=>' dta d'1234556789:;;<=>' dta d'1234456789:;<<=>' dta d'1233456789:;<==>' dta d'1223456789:;<=>>' dta d'0123456789:;<=>?' frsmpl dta b($20),b($22),b($24),b($26),b($29) dta b($2b),b($2e),b($30),b($33),b($37) dta b($3a),b($3d),b($41),b($45),b($49) dta b($4d),b($52),b($57),b($5c),b($61) dta b($67),b($6e),b($74),b($7b),b($82) dta b($8a),b($92),b($9b),b($a4),b($ae) dta b($b8),b($c3),b($cf),b($dc),b($e9) dta b($f6),b(5),b($15),b($25),b($37) dta b($49),b($5d),b($71),b($87),b($9f) dta b($b8),b($d2),b($ed),b($b),b($2a) dta b($4b),b($6e),b($93),b($ba),b($e3) dta b($f),b($3e),b($70),b($a4),b($db) frsmph dta d' ' dta d' ' dta d' !!!!!!!!!' dta d'!!!"""""""#####' *--- inicjacja iniadl dta l(inic0),l(inic2) dta l(inic4),l(inic5) dta l(inic6),l(inic7) dta l(inic8),l(inic9) iniadh dta h(inic0),h(inic2) dta h(inic4),h(inic5) dta h(inic6),h(inic7) dta h(inic8),h(inic9) init stx zapisx sty zapisy and #7 tay lda iniadl,y sta inic1+1 lda iniadh,y sta inic1+2 inic1 jmp $ffff inic0 lda zapisy ldx zapisx sta ainslz+1 sta ainshz+1 stx ainslz+2 stx ainshz+2 clc adc #$40 sta aptrlz+1 sta aptrhz+1 bcc i2 inx i2 stx aptrlz+2 stx aptrhz+2 clc adc #$80 sta t1frqz+1 bcc i4 inx i4 stx t1frqz+2 inx sta j4+1 stx j4+2 ldx #9 j4 lda $ffff,x sta adrtrl,x dex bpl j4 dec tempo inic2 lda #0 sta czygrc ldx <licptr-branch i9 sta branch,x dex bpl i9 ldx #8 k9 sta $d200,x dex bpl k9 rts inic4 jsr inic2 lda zapisx asl @ sta pozsng lda maxptr sta pozptr lda #1 sta zegar sta czygrc rts inic5 lda zapisy sta adrsmp lda zapisx sta adrsmp+1 j5 rts inic6 lda zapisy and #3 tax lda zapisx jsr n6 lda czysmp beq j5 asl zapisy j6 jsr nopy lda #1 sta typsmp j7 lda czysmp beq j5 cmp #1 bne j9 ldy #0 inc czysmp j9 lda (adrs2),y ldx wsksmp lsr @ lsr @ lsr @ lsr @ ora #$10 k15h1z sta $d40a sta $d40a sta $d201,x lda (adrs2),y ora #$10 k15h2z sta $d40a sta $d40a sta $d201,x iny bne j7 inc adrs2+1 lda adrs2+1 cmp lensmp bne j7 sty czysmp rts nopy bcc j8 lda #$ea sta k15h1z sta k15h1z+1 sta k15h1z+2 sta k15h2z sta k15h2z+1 sta k15h2z+2 rts j8 lda #$8d sta k15h1z sta k15h2z lda #$a sta k15h1z+1 sta k15h2z+1 lda #$d4 sta k15h1z+2 sta k15h2z+2 rts inic7 lda #0 sta czysmp lda zapisx lsr @ jsr nopy lda #1 sta typsmp k1 jsr j7 lda typsmp bne k1 rts inic9 ldy #0 sty typsmp sty czysmp dey sty kansmp rts k6 clc lda lsbmsb smpl1z adc #0 sta lsbmsb lda adrs1 smpl2z adc #0 sta adrs1 bcc k7 inc adrs1+1 lda adrs1+1 smpl3z cmp #0 bne k7 sty smpl1z+1 sty smpl2z+1 rts k7 lda (adrs1),y bit lsbmsb bmi k8 lsr @ lsr @ lsr @ lsr @ k8 and #15 tay volsmp lda volstb,y ldy #0 rts y1 lda typ beq y3 lda xdone cmp #$ff beq y5 y6 jsr play ldy #0 rts y3 lda pozsng cmp #4 bcc y6 inc typ ldx #1 stx dcb+2 dex stx dcb+3 y5 lda #$34 sta $d303 jsr play set ldy #0 sty xdone sty lindex lda #$23 sta $d20f lda #$10 sta $d20e lda #$31 sta $d20d sta cksum cli rts irq2 cmp #$20 bne irq3 lsr @ sta $d20e inc lindex ldx lindex cpx #4 bcs oi1 lda dcb,x sta $d20d clc adc cksum adc #0 sta cksum pla tax pla rti oi1 bne oi2 lda cksum sta $d20d pla tax pla rti oi2 lsr @ sta $d20e pla tax pla rti irq3 lda #$13 sta $d20f sta $d20a lda #$20 sta $d20e lda #$3c sta $d303 lda #$fe sta stcnt lda #0 sta cksum pla tax pla rti irq pha txa pha ldx #0 lda $d20e stx $d20e and #$30 cmp #$10 bne irq2 asl @ sta $d20e lda $d20f sta $d20a bpl error and #$20 beq error ldx stcnt bmi getsum lda $d20d sta bufor,x clc adc cksum adc #0 sta cksum inc stcnt pla tax pla rti getsum cpx #$80 beq ii1 inc stcnt lda $d20d cmp #$41 beq endirq cmp #$43 beq endirq error dec xdone lda #0 sta $d20e endirq pla tax pla rti ii1 lda $d20d sbc cksum bne error sta $d20e inc xdone pla tax pla rti *--- zmienne adrtrl org *+4 adrtrh org *+4 maxptr org *+1 tempo org *+1 branch org *+4 volume org *+4 adcvol org *+4 freq org *+4 frqwsk org *+4 adcdzw org *+4 poddzw org *+4 adrinl org *+4 adrinh org *+4 numdzw org *+4 numsmp org *+4 numptr org *+4 ptrwsk org *+4 ilespc org *+4 licspc org *+4 p1lsb org *+4 p1lic org *+4 p1pom org *+4 p2lic org *+4 p3max org *+4 p3lic org *+4 trnlic org *+4 zegar org *+1 pozsng org *+1 pozptr org *+1 wsksmp org *+1 kansmp org *+1 czysmp org *+1 typsmp org *+1 oraaud org *+1 licz org *+1 przech org *+1 licptr org *+1 *--- loader org $480 inic8 sei cld lda #$fe sta $d301 lda <irq sta $fffe lda >irq sta $ffff lda <jamp sta jump+1 lda >jamp sta jump+2 lda #2 sta typsmp sta kansmp ressmp lda #$18 sta $d207 lda <ressmp+1 sta adrs1 lda >ressmp+1 sta adrs1+1 lda #$ad sta drum1z sta drum2z sta drum3z sta drum4z ldy #1 sty gdzie dey sty smpl1z+1 sty smpl2z+1 sty typ sty xdone sty $d206 lda #$28 sta $d204 sta $d208 lda #$52 sta dcb+1 k2 ldx $d40b cpx #2 bcs y2 jsr y1 y2 lda (adrs2),y lsr @ lsr @ lsr @ lsr @ ora #$10 drum1z sta $d207 jsr k6 k3 cpx $d40b beq k3 sta $d205 ldx $d40b cpx #2 bcs y4 jsr y1 y4 lda (adrs2),y inc adrs2 bne k4 inc adrs2+1 dec lensmp bne k4 lda #$ad sta drum1z sta drum2z sta drum3z sta drum4z lda #8 k4 ora #$10 drum2z sta $d207 jsr k6 k5 cpx $d40b beq k5 sta $d205 lda xdone cmp #1 bne k2 sei ldy typ bmi x0 lda bufor+4 sta dcb+2 lda bufor+5 sta dcb+3 lda #$ff sta typ sta xdone bne k2 x0 iny sty lindex sty wsk lda bufor+$7e sta dcb+2 lda bufor+$7d and #3 sta dcb+3 ora dcb+2 beq l7 lda #$34 sta $d303 l7 sta l8+1 l1 ldx wsk cpx bufor+$7f bcc l5 l8 lda #$34 beq l9 jsr set jmp k2 l9 lda #1 jsr init jmp ($2e0) l5 lda bufor,x ldy gdzie beq l6 sta adr-1,y inc gdzie bne l0 l6 sta (adr),y l0 ldx $d40b cpx #2 bcs y7 jsr play y7 ldy #0 lda (adrs2),y lsr @ lsr @ lsr @ lsr @ ora #$10 drum3z sta $d207 jsr k6 l2 cpx $d40b beq l2 sta $d205 ldy gdzie bne x2 lda adr cmp end lda adr+1 sbc end+1 bcs x1 inc adr bne x3 inc adr+1 bne x3 x1 inc gdzie bne x3 x4 cpy #5 bne x3 lda #0 beq x5 x2 cpy #3 bne x4 lda adr and adr+1 eor #$ff bne x3 lda #1 x5 sta gdzie x3 ldx $d40b cpx #2 bcs y8 jsr play y8 ldy #0 lda (adrs2),y inc adrs2 bne l3 inc adrs2+1 dec lensmp bne l3 lda #$ad sta drum1z sta drum2z sta drum3z sta drum4z lda #8 l3 ora #$10 drum4z sta $d207 jsr k6 l4 cpx $d40b beq l4 sta $d205 inc wsk jmp l1 end Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 17, 2008 Share Posted April 17, 2008 I've got the next 4 days kinda free(ish), and I'd be very interested. Been wanting for ages to do a digi-player, using a kind of wrap-around "chase" buffer where it continuously loads and plays without interruption of either process. As I said elsewhere, 2 bit samples should be possible in realtime almost indefinately. But I guess the real-world application for all this would be game loaders with tunes + digi drums, cymbals, whatever. 2 voices + 1 or both of the remainders doing samples should be doable. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 17, 2008 Author Share Posted April 17, 2008 Rybags...first step would be to to rewrite and comment the irq-loader... but this should be not so hard. as it reads the $d20d (serin), reads 128 bytes, checks if errors and writes that back to the buffer ("bufor")...but first i would like to have a potential loader, MADS compatible and then exchanging the msx with another MPT digi track... http://en.wikipedia.org/wiki/Atari_POKEY Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 17, 2008 Author Share Posted April 17, 2008 well I understood the actual loader but where does the stuff jump to the MPT-music player? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 17, 2008 Share Posted April 17, 2008 Just starting on my own SIO routine here... Probably not the best way to go about things, but this is how I'll be doing it: - Custom Imm IRQ routine. For now, just to ensure top speed. As such, all other IRQs get disabled. Routine simply does I/O to RAM in the same fashion as the OS, bumps buffer pointer, sets appropriate flags etc at expected end of block. - VBlank Imm routine. It just sits there for the most part. But, it watches flags kicks off I/O when required (ie sends the initial byte of a cmd or data frame). Will also have to handle stuff like timeout detection. - "Get Sector" routine. Sets appropriate flags to get I/O started. Mainline code: SIO happens in the background, so the main program can prettywell do what it wants (within limits). It just has to periodically check a flag to see if an I/O operation is complete (ie, a "complete" operation in the sense of an entire sector of data has been transferred). As such, should leave processor totally free to do such things as play music, draw graphics, whatever. So long as it doesn't disable IRQs for any extended period of time. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 17, 2008 Author Share Posted April 17, 2008 (edited) ah. ok. seems you are right... the sample player in the energy loader is running as well while loading... (aehm... what a sentence... ) so the PC is staying at $580ff. and $10,$11 is the pointer to the samples... but how do you make sure that the sio 19200 bauds are not interrupting the player in an unwanded time? or is 4khz samples and 19200 baud perfect match? I am not good in maths so i do not know... Edited April 17, 2008 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
