coreysno Posted April 21, 2008 Share Posted April 21, 2008 hi does anyone know if you can play mame32 games with an air flow controller that has 4 buttons and a mini joystick and the thumb pad it works for me but the thumb pad part dont only the buttons and mini joytick works if anyone knows about this that would be great thanks Quote Link to comment Share on other sites More sharing options...
Cassidy Nolen Posted April 21, 2008 Share Posted April 21, 2008 I'm moving this topic over to Emulation as I see you have a few questions about it. I think they might be better questions for that forum. Hopefully you'll get some help getting it going. Good luck man! Cassidy Quote Link to comment Share on other sites More sharing options...
gary1068 Posted May 1, 2008 Share Posted May 1, 2008 hi does anyone know if you can play mame32 games with an air flow controller that has 4 buttons and a mini joystick and the thumb pad it works for me but the thumb pad part dont only the buttons and mini joytick works if anyone knows about this that would be great thanks Yes there is a way to play M.A.M.E. games with ANY psx style game controller it's somple. 1.) run M.A.M.E. and choose a game 2.) once the game loads press the the "Tab" key on your keyboard 3.) choose "Joystick" with up or down "arrow" keys and press the Enter key 4.)look at the sttings in that menu and choose whatever "P 1" configurations you want to change with the up or down "arrow" keys and press "Enter" 5.) when all changes have been made scroll down to the very bottom of the menu with the down "arrow" key then press "Enter" to get out of this menu 6.) you're back at the menu that appeared after you pressed the "Tab" key and use the down "arrow" key to srcroll to the VERY bottom of this menu first chyoose "Reset Game" Press "Enter" THEN choose "Return To Game" and press "Enter" for the last time. PLEASE remember to follow these steps for every game you play on M.A.M.E. Quote Link to comment Share on other sites More sharing options...
Buzbard Posted May 1, 2008 Share Posted May 1, 2008 hi does anyone know if you can play mame32 games with an air flow controller that has 4 buttons and a mini joystick and the thumb pad it works for me but the thumb pad part dont only the buttons and mini joytick works if anyone knows about this that would be great thanks Yes there is a way to play M.A.M.E. games with ANY psx style game controller it's somple. 1.) run M.A.M.E. and choose a game 2.) once the game loads press the the "Tab" key on your keyboard 3.) choose "Joystick" with up or down "arrow" keys and press the Enter key 4.)look at the sttings in that menu and choose whatever "P 1" configurations you want to change with the up or down "arrow" keys and press "Enter" 5.) when all changes have been made scroll down to the very bottom of the menu with the down "arrow" key then press "Enter" to get out of this menu 6.) you're back at the menu that appeared after you pressed the "Tab" key and use the down "arrow" key to srcroll to the VERY bottom of this menu first chyoose "Reset Game" Press "Enter" THEN choose "Return To Game" and press "Enter" for the last time. PLEASE remember to follow these steps for every game you play on M.A.M.E. Hmmm, you must be running an older version of MAME. For the newest versions, try this: 1.) run M.A.M.E. and choose a game 2.) once the game loads press the the "Tab" key on your keyboard 3.) select "Input (general)" then select "Player 1 controls" 4.) press "Enter" on each of the items in that menu followed by the button on your controller that you wish to use for that item 5.) when all changes have been made press "ESC" 6.) you're back at the menu that appeared after you pressed the "Tab" key press "ESC" again to return to the game It's not neccessary to do this for each game you will have set the default keys for all games. Good Luck! Quote Link to comment Share on other sites More sharing options...
gary1068 Posted May 5, 2008 Share Posted May 5, 2008 (edited) Buzbard well you were not specific on what M.A.M.E. 32 emulator you need help with when you had trouble configuring your Air Flow Controller. So i assumed that you had the same emulator of M.A.M.E. 32 that i have Edited May 5, 2008 by gary1068 Quote Link to comment Share on other sites More sharing options...
