Metallimirk Posted May 4, 2008 Share Posted May 4, 2008 Hi, I recently acquired a Nolan Bushnell Signature Series Atari 7800 Prototype System, along with some other development gadgets and accessories. I am still going thru the lot, but if you are intrested in adding this rare piece to your Atari collection the link to the auction is below. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=330233565355 Thanks and good luck! Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 5, 2008 Share Posted May 5, 2008 So are the guts in this prototype also or is it just an old retail 7800 board hardwired in there? Quote Link to comment Share on other sites More sharing options...
midnight8 Posted May 5, 2008 Share Posted May 5, 2008 So are the guts in this prototype also or is it just an old retail 7800 board hardwired in there? I wanna know the answer to this too. anyone know Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted May 5, 2008 Share Posted May 5, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 5, 2008 Share Posted May 5, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. Actually the new boards were designed and a handful were manufactured. I don't know if any were populated though. Mitch Quote Link to comment Share on other sites More sharing options...
Albert Posted May 6, 2008 Share Posted May 6, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. Actually the new boards were designed and a handful were manufactured. I don't know if any were populated though. Mitch I know at least one was fully populated, and it worked. I have a partially populated board that I will finish populating someday. Edit: I have confirmed that only one board was completely populated, and 25 boards were produced in total. ..Al Quote Link to comment Share on other sites More sharing options...
Super-Genius! Posted May 6, 2008 Share Posted May 6, 2008 All you need to do is look at the board! If it says Atari on it, it is not one of the 25 boards I made for this unit. I actually only populated ONE board. The amazing thing is, it worked the FIRST time I turned the unit on. I could not believe it. I have NO idea where that one board is. There are 24 more floating around, not sure if anyone populated them. I did make a few changes on the board from the original, so I am not sure anyone else but me would know the correct parts to populate the board with. For those of you interested, below is a link to a full scan of an unpopulated board. http://www.sunmarkinc.com/temp/7800_board.jpg Thanks, Mark Quote Link to comment Share on other sites More sharing options...
midnight8 Posted May 6, 2008 Share Posted May 6, 2008 All you need to do is look at the board! If it says Atari on it, it is not one of the 25 boards I made for this unit.I actually only populated ONE board. The amazing thing is, it worked the FIRST time I turned the unit on. I could not believe it. I have NO idea where that one board is. There are 24 more floating around, not sure if anyone populated them. I did make a few changes on the board from the original, so I am not sure anyone else but me would know the correct parts to populate the board with. For those of you interested, below is a link to a full scan of an unpopulated board. http://www.sunmarkinc.com/temp/7800_board.jpg Thanks, Mark So am i to assume that most likely winning bidder gets a custom case with a standard board in it? Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 6, 2008 Share Posted May 6, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. No there is proto's, you seem to be ill informed. Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted May 6, 2008 Share Posted May 6, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. No there is proto's, you seem to be ill informed. Yeah I should've read the other thread first. I thought they just made the shells, but I guess they did run a few PCB's and even poplulated one. I do believe that the board in this is most likely from a regular 7800 and not a new board though. Quote Link to comment Share on other sites More sharing options...
Rev Posted May 8, 2008 Share Posted May 8, 2008 All you need to do is look at the board! If it says Atari on it, it is not one of the 25 boards I made for this unit.I actually only populated ONE board. The amazing thing is, it worked the FIRST time I turned the unit on. I could not believe it. I have NO idea where that one board is. There are 24 more floating around, not sure if anyone populated them. I did make a few changes on the board from the original, so I am not sure anyone else but me would know the correct parts to populate the board with. For those of you interested, below is a link to a full scan of an unpopulated board. http://www.sunmarkinc.com/temp/7800_board.jpg Thanks, Mark great article!!! Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 11, 2008 Share Posted May 11, 2008 Congats Mitch!! Quote Link to comment Share on other sites More sharing options...
Mayhem Posted May 11, 2008 Share Posted May 11, 2008 I was tempted to bid (even at that price) but figured Mitch would come in for it... no need to push his costs up heh... (well I ASSUME that he would still win anyhows... who knows?!) Quote Link to comment Share on other sites More sharing options...
gambler172 Posted May 11, 2008 Share Posted May 11, 2008 Hi Mitch This was the price,i payed for mine too. greetings Walter Quote Link to comment Share on other sites More sharing options...
gambler172 Posted May 11, 2008 Share Posted May 11, 2008 The board has to be an old 7800 as the new boards never were designed or manufactured. There's a thread around that explains how these came to be. No there is proto's, you seem to be ill informed. Hi Shawn I own such a new proto board too,but only the empty board. greetings Walter Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 11, 2008 Share Posted May 11, 2008 I was tempted to bid (even at that price) but figured Mitch would come in for it... no need to push his costs up heh... (well I ASSUME that he would still win anyhows... who knows?!) Thanks for that. Mitch Quote Link to comment Share on other sites More sharing options...
doctorclu Posted May 15, 2008 Share Posted May 15, 2008 Wow, that is beautiful. Uploading the pictures up here for when the ebay auction phases off... Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 15, 2008 Share Posted May 15, 2008 Unfortunately the pictures don't show that the side panel is cracked and the back two screw posts are busted off. Mitch Quote Link to comment Share on other sites More sharing options...
mos6507 Posted May 15, 2008 Share Posted May 15, 2008 Still, it's a wonderful item. It's a pity they never offered it to the public. Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 15, 2008 Share Posted May 15, 2008 Unfortunately the pictures don't show that the side panel is cracked and the back two screw posts are busted off. Mitch So the dude flat out lied about the condition, what a loser. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 15, 2008 Share Posted May 15, 2008 I guess the screw posts are sort of mentioned: This system features the pro-production plastic housing that is only held together by front screws. It would be hard to see that they are broken without disassembling the system. The crack on the side seems a little hard to miss though and "Has a few scratches here and there" doesn't really cover it. Mitch Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 15, 2008 Share Posted May 15, 2008 I guess the screw posts are sort of mentioned: This system features the pro-production plastic housing that is only held together by front screws. It would be hard to see that they are broken without disassembling the system. The crack on the side seems a little hard to miss though and "Has a few scratches here and there" doesn't really cover it. Mitch Mitch you paid near a grand for that thing, dude was clearly being vauge to get top dollar for it. Quote Link to comment Share on other sites More sharing options...
midnight8 Posted May 15, 2008 Share Posted May 15, 2008 (edited) I guess the screw posts are sort of mentioned: This system features the pro-production plastic housing that is only held together by front screws. It would be hard to see that they are broken without disassembling the system. The crack on the side seems a little hard to miss though and "Has a few scratches here and there" doesn't really cover it. Mitch Mitch you paid near a grand for that thing, dude was clearly being vauge to get top dollar for it. I agree. With an item like that pics should have been made of the blemishes. A crack is a pretty big deal Edited May 16, 2008 by midnight8 Quote Link to comment Share on other sites More sharing options...
