Bakasama Posted May 29, 2008 Share Posted May 29, 2008 Since this board seems to have a fair number of programmers, I thought I would get some help with this. I'm trying adapt some of the code from Misfit MAME 122 to MacMAME 103a. After many hours of work I managed to get MacMAME to compile without errors with added code. One of things I'm trying to do is making MacMAME work with this. It's a hack that saves high scores from Crazy Kong into NVRAM. I managed to get MacMAME to load the game but I've hit a snag. The app crashed due to: "MacMAME has encounter a problem" "nvram handler called without nvram in the memory map" Me being not so great with C++, I found out what the problem is but I don't know how to fix it. Here's the code that's stumping me: static MACHINE_DRIVER_START( ckong ) MDRV_IMPORT_FROM(cclimber) MDRV_VISIBLE_AREA(0*8, 32*8-1, 2*8, 32*8-1) MACHINE_DRIVER_END static MACHINE_DRIVER_START( ckonghs ) /* basic machine hardware */ MDRV_IMPORT_FROM(ckong) MDRV_CPU_MODIFY("main") MDRV_CPU_PROGRAM_MAP(ckonghs_map,0) MDRV_NVRAM_HANDLER(generic_0fill) //problem code here MACHINE_DRIVER_END If anyone can tell me what I did wrong and help fix this, I would grateful. Quote Link to comment Share on other sites More sharing options...
