Frostbite Z Posted August 25, 2002 Share Posted August 25, 2002 I currently am using the small coaxial connector that I bought at Radio Shack, but would like the ability to have two systems plugged into the television set at the same time (it is a tv that is used only for gaming by the way). Any ideas or suggestions? Quote Link to comment Share on other sites More sharing options...
Warren Posted August 25, 2002 Share Posted August 25, 2002 I'd get another small RCA-Coax connector, connect both connectors to an A/B switch, and connect the A/B switch to the TV with a short Coax cable. Then just switch between the systems! Quote Link to comment Share on other sites More sharing options...
Frostbite Z Posted August 25, 2002 Author Share Posted August 25, 2002 Thanks! Is this the same one mentioned here on the site? Quote Link to comment Share on other sites More sharing options...
SS Posted August 26, 2002 Share Posted August 26, 2002 I've got 11 systems hooked up to my TV. Get a couple of selector boxes. I'd recommend an old-school (coaxial type) one for systems with switch boxes and a newer one for systems with direct (rca type) inputs. You can "daisy-chain" quite a few systems as well. Or do both if you don't have enough input spaces (like me!). Quote Link to comment Share on other sites More sharing options...
Warren Posted August 27, 2002 Share Posted August 27, 2002 Thanks! Is this the same one mentioned here on the site? Yes, it's the black box found on this page. The other idea for multiple systems is great, I have something between that idea and my suggestion on my systems. But for only two or three systems, I'd go with my original suggestion. Quote Link to comment Share on other sites More sharing options...
