sup8pdct Posted August 31, 2008 Share Posted August 31, 2008 I am in need of the above. Mine is at 2.11. it is fully optioned with Floppy board etc. I know Mathy's site has it BUT it is missing 2 parts. Thank you in advance. James Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted August 31, 2008 Share Posted August 31, 2008 (edited) you might find one on pigwa.nets ftp site...can't fully remember the exact link for the o/s or replace ment bios roms someone else may point you in a better direction Edited August 31, 2008 by carmel_andrews Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted September 3, 2008 Author Share Posted September 3, 2008 I am in need of the above.Mine is at 2.11. it is fully optioned with Floppy board etc. I know Mathy's site has it BUT it is missing 2 parts. Thank you in advance. James Update. The Pigwa site only has Old versions. I managed to assemble a complete rom from Mathy's site despite 2 missing parts. While pulling apart my rom to see how it was assembled with the intent of sending a file to mathy to get the complete image, I discovered 3 blocks of code are the same 2 of which are the missing ones. Simply copy bbpg11.bin twice and rename them to bbpg00 and bbpg10. Assemble the parts in order and you have the rom image. James Quote Link to comment Share on other sites More sharing options...
Mathy Posted September 3, 2008 Share Posted September 3, 2008 Hello James So you've got 2.16 running succesfully on your BlackBox? Greetings Mathy Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted September 4, 2008 Author Share Posted September 4, 2008 Hello James So you've got 2.16 running succesfully on your BlackBox? Greetings Mathy Yes indeed. works a treat. Tried everything except the floppy formater, but went into it to see so it should work. James Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted September 4, 2008 Share Posted September 4, 2008 For anyone else who may be attempting to follow this, the following may be relevant: If your black box had a 16k ROM in it, its possible that the A14 and A15 ROM adress lines are tied "hi".. What you should do is bend up pin 27 of the ROM, and solder a wire from that pin to pin 15 of the 74LS175. Then, bend up pin 1 of the ROM, and solder a wire from that pin to pin 12 of the 6821 chip. Finally, turn off DIP switch number 2. Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted September 4, 2008 Author Share Posted September 4, 2008 For anyone else who may be attempting to follow this, the following may be relevant: If your black box had a 16k ROM in it, its possible that the A14 and A15 ROM adress lines are tied "hi".. What you should do is bend up pin 27 of the ROM, and solder a wire from that pin to pin 15 of the 74LS175. Then, bend up pin 1 of the ROM, and solder a wire from that pin to pin 12 of the 6821 chip. Finally, turn off DIP switch number 2. While digging through the rom, I found 1 2K block to have a little message in it, It says: Please turn Dipswitch #2 off. Thanks. So no harm is done if Dipswitch 2 is on but the BB will always boot up with that message till it is Off James Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted September 4, 2008 Share Posted September 4, 2008 (edited) For anyone else who may be attempting to follow this, the following may be relevant: If your black box had a 16k ROM in it, its possible that the A14 and A15 ROM adress lines are tied "hi".. What you should do is bend up pin 27 of the ROM, and solder a wire from that pin to pin 15 of the 74LS175. Then, bend up pin 1 of the ROM, and solder a wire from that pin to pin 12 of the 6821 chip. Finally, turn off DIP switch number 2. While digging through the rom, I found 1 2K block to have a little message in it, It says: Please turn Dipswitch #2 off. Thanks. So no harm is done if Dipswitch 2 is on but the BB will always boot up with that message till it is Off James With Dipswitch #2 on, and the 64k ROM installed, you are pulling RA15 low at all times... This cuts your rom in half... Which is why you have to turn it off... Yes, it REMINDS you if you forget to turn it off.. When CSS went to the 64k ROM, they needed an extra Adress line, so they used the PORTB bit of the 6821 that USED TO CONTROL "hard disk/ultraspeed enable." The 2.16 firmware uses that bit (as an output) to select between the upper or lower 32K of the ROM, rather than reading it as an input from dipswitch number 2.... So yeah, Dipswitch 2 needs to be off, or it will only be able to access half the rom... Edited September 4, 2008 by MEtalGuy66 Quote Link to comment Share on other sites More sharing options...
