Ross PK Posted September 7, 2008 Share Posted September 7, 2008 Just wondering, as I can't really imagine what could happen. Quote Link to comment Share on other sites More sharing options...
mimo Posted September 7, 2008 Share Posted September 7, 2008 Bit rot Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 7, 2008 Share Posted September 7, 2008 Wear on the edge connector. Broken traces. Bad solder joins. Static/electrical damage to the ROM or EPROM. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted September 7, 2008 Share Posted September 7, 2008 98% chance that it'll work again. First, with the computer off, blow out the dust from the cartridge connector inside the computer. Turn the whole computer & shake it, to make sure that there are no warrens of dust bunnies living in there, when doing so. Now, just unscrew the cartridge case, then clean all of the gold contacts with the pink eraser end of a brand new #2 pencil. Be sure to blow out all of the eraser residue. Reassemble. Plug in. Turn on. Should now work. If not, with the power off, insert & detach the cartridge 20 times. If that doesn't clear up the problem, swab some alcohol on the cartridge's connector (thickly, so it is wet). With the computer off, try the above mentioned 20 times trick. Blow into the cartridge port, wait 30 seconds. Turn it on. This will clear up most cartridge problems. If the above procedure doesn't work, then the cartridge is pretty screwed, and will require additional troubleshooting, which may be beyond your ken. See the pinned "Tricks & Tips for Restoration" for other info on bringing your system out of mothballs. L8R. Quote Link to comment Share on other sites More sharing options...
Ross PK Posted September 7, 2008 Author Share Posted September 7, 2008 I don't have a dead cartridge, but thanks. I do have some carts which don't always work first time, especially Moon Patrol, I have to plug it into the computer and take it out several times before I can get it to work. Do you or anyone know how to unscrew the brown official Atari carts? I've tried but the screws are always too damned tight. Quote Link to comment Share on other sites More sharing options...
classics Posted September 7, 2008 Share Posted September 7, 2008 I think they mostly die of loneliness. Steve Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted September 7, 2008 Share Posted September 7, 2008 I have a Star Raiders cart that died. One of the 2 rom chips is bad. I figured it out after cleaning all contacts and then swapping out the chips from a known good cart. Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted September 7, 2008 Share Posted September 7, 2008 I think they mostly die of loneliness. Quote Link to comment Share on other sites More sharing options...
a8maestro Posted September 10, 2008 Share Posted September 10, 2008 Bit rot from cosmic rays, voltage spikes, static electricity, imperfect production methods, impurities. But cleaning the contacts is a must, reseating chip when possible, can help a actual good cart. Rick D. Quote Link to comment Share on other sites More sharing options...
atariksi Posted September 12, 2008 Share Posted September 12, 2008 98% chance that it'll work again. First, with the computer off, blow out the dust from the cartridge connector inside the computer. Turn the whole computer & shake it, to make sure that there are no warrens of dust bunnies living in there, when doing so. Now, just unscrew the cartridge case, then clean all of the gold contacts with the pink eraser end of a brand new #2 pencil. Be sure to blow out all of the eraser residue. Reassemble. Plug in. Turn on. Should now work. If not, with the power off, insert & detach the cartridge 20 times. If that doesn't clear up the problem, swab some alcohol on the cartridge's connector (thickly, so it is wet). With the computer off, try the above mentioned 20 times trick. Blow into the cartridge port, wait 30 seconds. Turn it on. This will clear up most cartridge problems. If the above procedure doesn't work, then the cartridge is pretty screwed, and will require additional troubleshooting, which may be beyond your ken. See the pinned "Tricks & Tips for Restoration" for other info on bringing your system out of mothballs. L8R. That's pretty good. Throw in that using a flat screw driver to rub the contacts if cartridge has thick dust or some oxidation effect. Quote Link to comment Share on other sites More sharing options...
