Wickeycolumbus Posted September 21, 2008 Share Posted September 21, 2008 (edited) I was experimenting with reseting the h position register mid line in several spots during the line and I came up with this kernel. It puts Each sprite on the screen 7 times for a total of 14 sprites or 112 pixels and saves 22 cycles for housekeeping with no flicker. I dont think that it is possible to change the graphics of each copy though... SpriteDemo.zip Edited September 22, 2008 by Wickeycolumbus Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted September 22, 2008 Author Share Posted September 22, 2008 Optimized a bit. Now you have ~19 cycles at the begining for housekeeping, then you have 5 cycles for graphic changing in between resetting horizontal positions. There are also 16 sprites now for a total of 128 pixels. spriteDemoChange.bin Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted September 22, 2008 Author Share Posted September 22, 2008 (edited) Kernel greatly improved. Still 128 pixels, Removed WSYNC write and saved 11 cycles. Here is the template for the kernel if anyone is interested: somewhere in game: lda #%00000011 sta NUSIZ0 sta NUSIZ1 Main Kernel: sta WSYNC Kernel nop nop nop nop nop nop ;; 20 cycles for house keeping nop nop nop nop sta RESP0 sta RESP1 nop 0 ;; 5 cycles for graphics changing nop sta RESP0 sta RESP1 nop 0 nop sta RESP0 sta RESP1 nop 0 nop 0;; 11 cycles for house keeping nop 0 nop dey bne Kernel attached is an example. EDIT: I miss calcualted. You can have up to 10 cycles in between each reposition of the sprites, enough to change the graphics of player one and two. spriteDemoChange2.bin Edited September 22, 2008 by Wickeycolumbus Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted September 24, 2008 Share Posted September 24, 2008 Kernel greatly improved. Still 128 pixels, Removed WSYNC write and saved 11 cycles. Here is the template for the kernel if anyone is interested:[...] EDIT: I miss calcualted. You can have up to 10 cycles in between each reposition of the sprites, enough to change the graphics of player one and two. Kinda cool, though fairly limited since the graphics have to be of the form: ABABCDCDEFEFGHGH Though your demo doesn't change colors and uses 2-line resolution for the sprites, I assume that neither of those are a necessary limitation? Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted September 24, 2008 Author Share Posted September 24, 2008 Though your demo doesn't change colors and uses 2-line resolution for the sprites, I assume that neither of those are a necessary limitation? Yea, sprites can be 1 line and you can change colors as long as you have enough time to. I'll put together another demo demonstrating this sometime. Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted October 5, 2008 Author Share Posted October 5, 2008 This demonstrates 1-line resolution sprites that change color every line. It can easily be adapted to change graphics one or two times also. spriteDemoColor.bin Quote Link to comment Share on other sites More sharing options...
roland p Posted October 6, 2008 Share Posted October 6, 2008 Any chances in positioning the sprites at equal distances? You could create nice grid-like graphics then. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted October 6, 2008 Share Posted October 6, 2008 Here are some screenshots: 1st ROM: 2nd ROM: Quote Link to comment Share on other sites More sharing options...
Eckhard Stolberg Posted October 6, 2008 Share Posted October 6, 2008 Any chances in positioning the sprites at equal distances? You could create nice grid-like graphics then. It is possible to position the sprites at equal distances, but you'd either have to increase the gap between them a bit or fill the entire line using 9 copies of each player. Increasing the gap might be too much for a nice looking grid. But it has the advantage that the sprites could be disabled individually. Christopher Tumber uses this in his game Space Instigators. Filling the entire line with 18 spites allows you to display a nice grid. But there isn't enough time to update the graphics and colours for both players in each scanline. I posted some experiments with this effect to the [stella] mailing list about 10 years ago. Multi5.bin displays a screen filling pattern. Grid2.bin displays a grid that you can scroll left and right. And extra18.bin displays 18 sprites that you can hide with the joystick. The sprites in the last one aren't positioned at equally distances though. multi5.binGRID2.BINEXTRA18.BIN Ciao, Eckhard Stolberg Quote Link to comment Share on other sites More sharing options...
