Battlezone Posted September 24, 2008 Share Posted September 24, 2008 (edited) It's Chip's Challenge. No "insert game" this time. I insert the game in the cartridge slot but after few seconds it turns off the console. Edited September 24, 2008 by Battlezone Quote Link to comment Share on other sites More sharing options...
matashen Posted September 24, 2008 Share Posted September 24, 2008 It's Chip's Challenge. No "insert game" this time. I insert the game in the cartridge slot but after few seconds it turn offs the console. It could be a failure in some bytes, when the Lynx decodes the first Blocks of the cart. Greatings Matthias Quote Link to comment Share on other sites More sharing options...
per Posted September 24, 2008 Share Posted September 24, 2008 It's Chip's Challenge. No "insert game" this time. I insert the game in the cartridge slot but after few seconds it turn offs the console. I had the excact same problem. After I inserted the game a coupple of times (and after blowing at the cartridge slot, even though I don't know how smart THAT is), it worked for me. I don't know if it is the same problem, but the sympthoms are exactly the same. Quote Link to comment Share on other sites More sharing options...
eightbit Posted October 1, 2008 Share Posted October 1, 2008 Try cleaning the contacts with isopropyl 91% alcohol and q-tips. I have had MANY titles exhibit this behavior, and this has always done the trick (sometimes multiple cleanings were needed however) Quote Link to comment Share on other sites More sharing options...
midnight8 Posted October 1, 2008 Share Posted October 1, 2008 Try cleaning the contacts with isopropyl 91% alcohol and q-tips. I have had MANY titles exhibit this behavior, and this has always done the trick (sometimes multiple cleanings were needed however) Same here. I used an old tooth brush and alcohol though. Quote Link to comment Share on other sites More sharing options...
Battlezone Posted October 1, 2008 Author Share Posted October 1, 2008 Try cleaning the contacts with isopropyl 91% alcohol and q-tips. I have had MANY titles exhibit this behavior, and this has always done the trick (sometimes multiple cleanings were needed however) Same here. I used an old tooth brush and alcohol though. I tryed with denaturated alcohol, I usually clean contacts with it, but it didn't work this time. Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted October 3, 2008 Share Posted October 3, 2008 I'd be happy to rip the label off and poke around inside it AX Quote Link to comment Share on other sites More sharing options...
