+Random Terrain Posted October 27, 2008 Share Posted October 27, 2008 Here are two similar if-then statements: if a=255 && b>c then goto moosenipple if a=255 then if b>c then goto moosenipple Is one faster than the other or do they both take the same amount of time? Seems like the second one would be faster, but I don't know what happens to them after they are compiled. Thanks. Quote Link to comment Share on other sites More sharing options...
yuppicide Posted October 27, 2008 Share Posted October 27, 2008 I've never used the second one, and actually I never even knew it was possible! Here are two similar if-then statements: if a=255 && b>c then goto moosenipple if a=255 then if b>c then goto moosenipple Is one faster than the other or do they both take the same amount of time? Seems like the second one would be faster, but I don't know what happens to them after they are compiled. Thanks. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 27, 2008 Share Posted October 27, 2008 (edited) They should both take the same amount of time from what I can tell. LDA A CMP #$FF BNE nojump LDA B CMP C BCC nojump JMP moosenipple nojump: Right? Edited October 27, 2008 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 27, 2008 Share Posted October 27, 2008 They should both take the same amount of time from what I can tell. LDA A CMP #$FF BNE nojump LDA B CMP C BCC nojump JMP moosenipple nojump: Right? I can't compile a test right now, but I believe you're right-- they should compile to essentially the same code, although there will be some differences in the jump labels that bB creates when it's compiling them. Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 27, 2008 Author Share Posted October 27, 2008 I can't compile a test right now, but I believe you're right-- they should compile to essentially the same code, although there will be some differences in the jump labels that bB creates when it's compiling them. If you find out they're the same, that will be good to know. I could use either one and won't have to worry about which is faster. While we're on the subject of speed, do you know if a for-next loop is faster than a fake for-next loop? Here's a real for-next loop: for x = 1 to 20 [Mind-blowing code goes here.] next Here's a fake for-next loop: temp5 = 0 : temp6 = 20 fingernailpudding temp5 = temp5 + 1 [Mind-blowing code goes here.] if temp5<temp6 then goto fingernailpudding I hope the fake for-next loop isn't slower since it's useful if the code in the middle needs to jump out of there if a certain condition is met. Thanks. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 27, 2008 Share Posted October 27, 2008 I can't compile a test right now, but I believe you're right-- they should compile to essentially the same code, although there will be some differences in the jump labels that bB creates when it's compiling them. If you find out they're the same, that will be good to know. I could use either one and won't have to worry about which is faster. While we're on the subject of speed, do you know if a for-next loop is faster than a fake for-next loop? Here's a real for-next loop: for x = 1 to 20 [Mind-blowing code goes here.] next Here's a fake for-next loop: temp5 = 0 : temp6 = 20 fingernailpudding temp5 = temp5 + 1 [Mind-blowing code goes here.] if temp5<temp6 then goto fingernailpudding I hope the fake for-next loop isn't slower since it's useful if the code in the middle needs to jump out of there if a certain condition is met. Thanks. I'll check them out tonight. But first I absolutely must watch Heroes. (That's right. I don't care if the rest of the people in the world supposedly think that Heroes sucks these days, there are so very few TV shows that I care to watch anymore, and Heroes is definitely one of them.) Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 27, 2008 Author Share Posted October 27, 2008 I'll check them out tonight. But first I absolutely must watch Heroes. (That's right. I don't care if the rest of the people in the world supposedly think that Heroes sucks these days, there are so very few TV shows that I care to watch anymore, and Heroes is definitely one of them.) It's in my list of favorite shows: http://www.randomterrain.com/personal-movies-tv-f-m.html Those pages need to be updated. I have a few more shows I need to add to the list. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 28, 2008 Share Posted October 28, 2008 The two ifs you posted compile exactly the same (except for the labels that bB creates): 1515 f48f .L01 ; if a = 255 && b > c then goto moosenipple 1516 f48f 1517 f48f a5 d6 LDA a 1518 f491 c9 ff CMP #255 1519 f493 d0 09 BNE .skipL01 1520 f495 .condpart0 1521 f495 a5 d8 LDA c 1522 f497 c5 d7 CMP b 1523 f499 b0 03 BCS .skip0then 1524 f49b .condpart1 1525 f49b 4c bf f4 jmp .moosenipple 1526 f49e 1527 f49e .skip0then 1528 f49e .skipL01 1529 f49e . 1530 f49e ; 1531 f49e 1532 f49e .L02 ; if a = 255 then if b > c then goto moosenipple 1533 f49e 1534 f49e a5 d6 LDA a 1535 f4a0 c9 ff CMP #255 1536 f4a2 d0 09 BNE .skipL02 1537 f4a4 .condpart2 1538 f4a4 a5 d8 LDA c 1539 f4a6 c5 d7 CMP b 1540 f4a8 b0 03 BCS .skip2then 1541 f4aa .condpart3 1542 f4aa 4c bf f4 jmp .moosenipple 1543 f4ad 1544 f4ad .skip2then 1545 f4ad .skipL02 However, you can save a few bytes and a few cycles if you leave off the goto-- as long as moosenipple isn't too far away: 1515 f48f .L01 ; if a = 255 && b > c then moosenipple 1516 f48f 1517 f48f a5 d6 LDA a 1518 f491 c9 ff CMP #255 1519 f493 d0 06 BNE .skipL01 1520 f495 .condpart0 1521 f495 a5 d8 LDA c 1522 f497 c5 d7 CMP b 1523 f499 90 18 bcc .moosenipple 1524 f49b .skipL01 1525 f49b . 1526 f49b ; 1527 f49b 1528 f49b .L02 ; if a = 255 then if b > c then moosenipple 1529 f49b 1530 f49b a5 d6 LDA a 1531 f49d c9 ff CMP #255 1532 f49f d0 06 BNE .skipL02 1533 f4a1 .condpart1 1534 f4a1 a5 d8 LDA c 1535 f4a3 c5 d7 CMP b 1536 f4a5 90 0c bcc .moosenipple 1537 f4a7 .skipL02 On the other hand, the fake for next that you posted is longer than the real for next: 1515 f48f .L01 ; for x = 1 to 20 1516 f48f 1517 f48f a9 01 LDA #1 1518 f491 85 ed STA x 1519 f493 .L01forx 1520 f493 .L02 ; a = a + 1 1521 f493 1522 f493 e6 d6 INC a 1523 f495 .L03 ; next 1524 f495 1525 f495 a5 ed LDA x 1526 f497 c9 14 CMP #20 1527 f499 1528 f499 e6 ed INC x 1529 f49b 90 f6 bcc .L01forx 1530 f49d . 1531 f49d ; 1532 f49d 1533 f49d .L04 ; temp5 = 0 : temp6 = 20 1534 f49d 1535 f49d a9 00 LDA #0 1536 f49f 85 a0 STA temp5 1537 f4a1 a9 14 LDA #20 1538 f4a3 85 a1 STA temp6 1539 f4a5 .fingernailpudding 1540 f4a5 ; fingernailpudding 1541 f4a5 1542 f4a5 .L05 ; temp5 = temp5 + 1 1543 f4a5 1544 f4a5 e6 a0 INC temp5 1545 f4a7 .L06 ; a = a + 1 1546 f4a7 1547 f4a7 e6 d6 INC a 1548 f4a9 .L07 ; if temp5 < temp6 then goto fingernailpudding 1549 f4a9 1550 f4a9 a5 a0 LDA temp5 1551 f4ab c5 a1 CMP temp6 1552 f4ad b0 03 BCS .skipL07 1553 f4af .condpart0 1554 f4af 4c a5 f4 jmp .fingernailpudding 1555 f4b2 1556 f4b2 .skipL07 But you can do it in the same amount of space and time if you rearrange it, drop temp6, and leave off the goto: 1515 f48f .L01 ; for x = 1 to 20 1516 f48f 1517 f48f a9 01 LDA #1 1518 f491 85 ed STA x 1519 f493 .L01forx 1520 f493 .L02 ; a = a + 1 1521 f493 1522 f493 e6 d6 INC a 1523 f495 .L03 ; next 1524 f495 1525 f495 a5 ed LDA x 1526 f497 c9 14 CMP #20 1527 f499 1528 f499 e6 ed INC x 1529 f49b 90 f6 bcc .L01forx 1530 f49d . 1531 f49d ; 1532 f49d 1533 f49d .L04 ; temp5 = 1 1534 f49d 1535 f49d a9 01 LDA #1 1536 f49f 85 a0 STA temp5 1537 f4a1 .fingernailpudding 1538 f4a1 ; fingernailpudding 1539 f4a1 1540 f4a1 .L05 ; a = a + 1 1541 f4a1 1542 f4a1 e6 d6 INC a 1543 f4a3 .L06 ; temp5 = temp5 + 1 1544 f4a3 1545 f4a3 e6 a0 INC temp5 1546 f4a5 .L07 ; if temp5 <= 20 then fingernailpudding 1547 f4a5 1548 f4a5 a9 14 LDA #20 1549 f4a7 c5 a0 CMP temp5 1550 f4a9 b0 f6 bcs .fingernailpudding Michael 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 28, 2008 Author Share Posted October 28, 2008 Thanks. That's some good stuff to know. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 28, 2008 Author Share Posted October 28, 2008 By the way, is there a guideline about how far too far is when not using goto with an if-then? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 28, 2008 Share Posted October 28, 2008 By the way, is there a guideline about how far too far is when not using goto with an if-then? Yes, it must be within plus or minus 128 bytes of the next statement after the if, since a branch can only go forward 127 bytes or backwards 128 bytes. Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 28, 2008 Author Share Posted October 28, 2008 By the way, is there a guideline about how far too far is when not using goto with an if-then? Yes, it must be within plus or minus 128 bytes of the next statement after the if, since a branch can only go forward 127 bytes or backwards 128 bytes. Thanks. I need to fit that in somewhere on the bB page. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 29, 2008 Share Posted October 29, 2008 By the way, is there a guideline about how far too far is when not using goto with an if-then? Yes, it must be within plus or minus 128 bytes of the next statement after the if, since a branch can only go forward 127 bytes or backwards 128 bytes. Thanks. I need to fit that in somewhere on the bB page. The best place would be in the section about smartbranching, because what the smartbranching option does is let you do something like "if a=1 then reset_the_game" instead of "if a=1 then goto reset_the_game," and the bB compiler will pick the best type of "then"-- "then routine_name" or "then goto routine_name." In other words, smartbranching lets you write your code as if you want to always use the shorter method, but you don't have to worry about whether the place you want to branch to is too far away, because bB will automatically handle it correctly for you. Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 29, 2008 Author Share Posted October 29, 2008 By the way, is there a guideline about how far too far is when not using goto with an if-then? Yes, it must be within plus or minus 128 bytes of the next statement after the if, since a branch can only go forward 127 bytes or backwards 128 bytes. Thanks. I need to fit that in somewhere on the bB page. The best place would be in the section about smartbranching, because what the smartbranching option does is let you do something like "if a=1 then reset_the_game" instead of "if a=1 then goto reset_the_game," and the bB compiler will pick the best type of "then"-- "then routine_name" or "then goto routine_name." In other words, smartbranching lets you write your code as if you want to always use the shorter method, but you don't have to worry about whether the place you want to branch to is too far away, because bB will automatically handle it correctly for you. Thanks. Here's a question about smartbranching. The bB info says that smartbranching makes the assembly code harder to read. Is that the only bad thing about it? Does it end up making a program run slower? If not, should we just use it all of the time in our programs so we don't have to waste time figuring out when to use 'then goto' by trial and error? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 29, 2008 Share Posted October 29, 2008 Thanks. Here's a question about smartbranching. The bB info says that smartbranching makes the assembly code harder to read. Is that the only bad thing about it? Does it end up making a program run slower? If not, should we just use it all of the time in our programs so we don't have to waste time figuring out when to use 'then goto' by trial and error? No, it shouldn't make the program slower. The reason it can make the assembly harder to read is because it will generate some conditional assembly directives that tell the assembler to do it one way or another depending on how far away the target of the branch is. bB's standard kernel already has a bunch of stuff like that in it, so if you ever look at the .lst file of your program, you'll see a bunch of stuff that can look overwhelmingly complicated if you aren't used to it. Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 29, 2008 Author Share Posted October 29, 2008 Thanks. Then I'll just have it turned on all of the time and not worry about it. Nice to know it doesn't slow anything down. Quote Link to comment Share on other sites More sharing options...
